Need help identifying thing on the fuel pump assembly - TCCoA Forums
post #1 of 5 (permalink) Old 05-08-2018, 04:10 PM Thread Starter
That red thing clamped to the end of the return line, with the arrow pointing to it "fuel return"
1. What is it called?
2. What does it do?
3. Where can I buy one?
4. Is it even necessary?
Mine tore off when I pulled a doner right pump assembly out of the tank. I have an idea what the answer to #2 is - presumably a check valve allowing returning fuel into the tank, but not tank fuel back in the return line(because that helps...?) - it seems to be there on every new pump assembly, and is likely used on numerous ford return pump assemblies, but I can't find anything resembling it separately on rockauto.
post #2 of 5 (permalink) Old 05-08-2018, 06:14 PM
IDK what it's called, but it's the part that makes a whoopee cushion.
It's a cheap, low pressure one-way valve.
Grog6 is online now
post #3 of 5 (permalink) Old 05-08-2018, 06:34 PM
97 30th's Avatar
Duck bill valve
You can't fix stupid
97 30th is online now
post #4 of 5 (permalink) Old 05-08-2018, 06:50 PM Thread Starter
Thanks mike! That led me to do some sleuthing, this seems to be a match
https://www.npdlink.com/store/produc...5211-6132.html
File Type: jpeg B71F455B-E389-4027-A272-D351F9D4C26A-11329-000029AD6FDCE17D.jpeg (16.1 KB, 23 views)
post #5 of 5 (permalink) Old 05-08-2018, 11:06 PM
97 30th's Avatar
Your welcome. See us older guys are good for something once in awhile That one should work.
