Blower Motor Stuck On High Speed - TCCoA Forums
post #1 of 1 (permalink) Old 06-22-2018, 03:36 PM Thread Starter
Tbird Bob's Avatar
Well, I was driving along, minding my business when out of a clear blue sky, flash, bam, ala kazam, this happened:
In a previous thread I discussed by AC woes, and the problem which has newly popped up.
Because the AC doesn't work, I had my climate control set to PANEL, so I could blow some cool air into the car. Without warning, the fan went to the highest setting, and is now stuck there. The dash controls are dead.
I know I need to replace some electronics on this 1997. A knowledgeable mechanic told me I need to replace the blower motor resistor unit behind the dash.
Anybody been there, done that? In order to drive the car I have the blower motor unplugged.
Is this the failed part?
https://www.rockauto.com/en/moreinfo...140613&jsn=516
Airtex Blower Motor Resistors Feature:
Ceramic coated steel printed circuit board design for durability and longevity
Thermal fuse equipped
Thicker trace widths than OE
Mounting and connector identical to OE
Connector Gender Female
Connector Quantity 2
Connector Shape Square, Rectangular
Terminal Gender Male
Terminal Quantity 5
Terminal Type Blade
Wiring Harness Included No
Alternate/OEM Part Number(s): 4P1530, F3LY19E624A, F5LY19E624A, FL3Y19E624A, JA1653, JA1704, Y17Z19E624AA, YL7Z19E624AA
Warranty Information:
3 Years/36,000 Miles
Tbird Bob is offline
