Fuel Filler Neck to Fuel Tank Hose Part Number - TCCoA Forums
post #1 of 8 (permalink) Old 11-27-2018, 09:05 PM Thread Starter
MaddMartigan's Avatar
Does anyone happen to know the part number of the rubber hose(s) that go from the filler neck to the fuel tank?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #2 of 8 (permalink) Old 11-27-2018, 10:27 PM
That was unobtanium in 2005; I got mine from a JY.
I'll look, I have the number somewhere.
post #3 of 8 (permalink) Old 11-28-2018, 05:12 AM Thread Starter
OK. TBSC Shop has it but I'm not paying that much for that old ass used part. I'll just do what I always do.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #4 of 8 (permalink) Old 11-28-2018, 09:10 AM
Wow. That is steep.
I saw new ones for up to 93's, but later is different apparently.
post #5 of 8 (permalink) Old 11-28-2018, 09:28 AM Thread Starter
Wow. That is steep.
Where did you find new ones for up to 93's? I have a 92/93 setup so I'm interested.
I bought one for a Ranger that looks to be the correct general size but it's longer so I can cut it down. However, if I see that it doesn't work then another option is a good plan.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #6 of 8 (permalink) Old 11-28-2018, 10:28 AM
These guys; I had a link looking for someone else's car.
https://www.fillernecksupply.com/198...eck-e9sz9034a/
post #7 of 8 (permalink) Old 11-28-2018, 10:40 AM
That’s the whole metal filler neck, he’s looking for the rubber section that goes between it and the tank
post #8 of 8 (permalink) Old 11-28-2018, 10:45 AM
This?
https://www.fillernecksupply.com/sea...ection=product
My 96 was all plastic/rubber.
