Lighting issue - TCCoA Forums
 3Likes
  • 1 Post By Thunderbird Pilot 89
  • 2 Post By RalphP
post #1 of 8 (permalink) Old 03-02-2019, 01:55 PM Thread Starter
Question Lighting issue
My 97 LX has developed a problem with no tail lights, dash lights or marker lights. Happened all of a sudden.
Was thinking either headlight switch or fuses. Fuses in order.
After an exhaustive search for how to replace the headlight switch , I am turning to you folks for help. The Haynes Manual doesn't cover the 97 model
dash/switch R/R .
Anybody got input on this ? It would be greatly appreciated.
1997 Thunderbird LX
White Pearl
274k
MY97 is offline
post #2 of 8 (permalink) Old 03-02-2019, 03:27 PM
Never had a tail light problem, but my 89 had headlights going in and out a few years ago. Replacing the switch fixed it. Easy job, just had to remove the trim panel from around the cluster to access the switch. Here's a diagram that should help.
MY97 likes this.
Thunderbird Pilot 89 is offline
post #3 of 8 (permalink) Old 03-02-2019, 03:43 PM
A few notes.
1) Toss that Haynes. It sucks. Pick up the Ford Factory Service Manual and a Ford Electrical Vacuum Troubleshooting Manual (FSM and EVTM). NOW. (Ebay usually has them on hand)
2) Be very, Very, VERY careful removing that dash surround. Surrounds without broken tabs are like honest politicians - I'm sure there's some out there, but nobody can find one!
3) While the surround is off, I'd consider replacing the cluster lights - 194s, 2827s, the good LEDs, etc.
Thunderbird Pilot 89 and MY97 like this.
Fuelly
RalphP is offline
post #4 of 8 (permalink) Old 03-02-2019, 03:46 PM Thread Starter
Thank you... did a little 'eyeballing' but your diagram will help immensely.... fun times.
MY97 is offline
post #5 of 8 (permalink) Old 03-02-2019, 03:48 PM Thread Starter
274000 and still getting 22-24 mpg ... all highway miles...
MY97 is offline
post #6 of 8 (permalink) Old 03-02-2019, 05:23 PM
quickford's Avatar
I had that happen before, it was also around the time the headlight switch had to be replaced, which caused confusion in my troubleshooting, but I think it turned out to be a fuse after all.
Current poor life choices: 1991 Mercury Cougar XR7, 1998 Lincoln Town Car, 2005 Ford Focus ST, 1997 Ford Probe GT.
Previously: 2015 Focus, 1996 Thunderbird, 1998 Taurus, 1989 Escort.
quickford is offline
post #7 of 8 (permalink) Old 03-02-2019, 06:27 PM Thread Starter
All fuses are good... bulbs etc good also
MY97 is offline
post #8 of 8 (permalink) Old 03-03-2019, 12:19 PM
I'd start here:
https://www.ebay.com/itm/1997-FORD-T...PgV3:rk:7:pf:0
The MFS, or blinker switch can cause the tail lights and brake lights to go out, but it has nothing to do with the accent lights.
Similar Threads
Like to fix.. ac issue Anyone confirm what part/issue looking at here 1991 5.0 General Tech 5 06-19-2018 05:49 AM
Power Window Issue, Jammed closed, possibly track issue? DigitalHorizons Interior 19 05-15-2017 08:28 AM
Catalytic issue after plug issue after manifold issue DDBThunderbird General Tech 3 01-31-2012 02:39 PM
serious issue sub and amp issue RedBirdSC Audio / Electronics 2 11-23-2002 07:42 PM
Neons Interior Lighting Pics Wanted Jstaib Interior 2 09-04-2002 07:13 AM
