Remove Y-pipe & tranny xmember - TCCoA Forums
 1Likes
  • 1 Post By XR7-4.6
post #1 of 14 (permalink) Old 03-10-2019, 08:01 PM Thread Starter
I'm back at working on the Smurf (96 Cougar stock). I'm struggling with removing the front exhaust & tranny cross member. I've searched and can't find what I'm looking for. I disconnected the exhaust but can't slide it back far enough to get the hangers to slide out of the tubes. Is there a trick here? Can I remove the whole mounting bracket from the tranny to get the exhaust out? Do I need the exhaust out to get the tranny cross member off the car? I had the xmember unbolted, but could not fan-angle it out with the exhaust in the way. Thanks for any help.
Kidd-7 is offline
post #2 of 14 (permalink) Old 03-10-2019, 08:50 PM
Couple things to look for with the exhaust. The exhaust manifolds have studs which might be catching the flanges as you try to pull it back, preventing you from sliding the exhaust out of the mount unless you get the angle right. With the driveshaft and driveshaft loops/gas tank still in place, you can unbolt the trans. crossmember to give you a little more room to maneuver the exhaust without the trans falling. I'd suggest putting a floor jack under it to ease the "shock" of the slack in the bind that the driveshaft will cause, after the bolts let go from the body. Also shoot a bunch of penetrant of choice (PB, WD40, Liquid Wrench etc.) into that rubber exhaust mount on the trans crossmemeber, it'll help them slide out a lot easier.
post #3 of 14 (permalink) Old 03-10-2019, 09:30 PM
dDUBb's Avatar
You need to remove the back half of the exhaust if you want to drop the front half / Y pipe assembly. It will get in your way and prevent you from removing the hangers out of the transmission x-member. Once the back half is off the car, or at least dropped at the hanger near the IRS, you may need to use a hammer to slide the hangers out of the trans X-member portion.
dDUBb is offline
post #4 of 14 (permalink) Old 03-11-2019, 08:37 AM
I don't remember all the details now but I do remember struggling with it for quite a while. Posted a description shortly after I completed the project.
https://forums.tccoa.com/7-engine-4-...-lx-4-6-a.html
I was really impressed that at 22 years old I was able to reuse all the fasteners and hardware, except couple of the exhaust manifold studs I broke. Plenty of oil, PB blaster, and heat.
Jim3inVirginia is offline
post #5 of 14 (permalink) Old 03-11-2019, 09:19 AM
just grab a dead blow mallet and give that sumbitch hell, they get gunk and rust in those hangars that make them stick.
the middle pipe will be in the way, and yes it can catch on the studs as you're trying to pull it
Djose13 is offline
post #6 of 14 (permalink) Old 03-11-2019, 11:36 AM
I seem to remember using a scissor jack between the third cat and crossmember when I’d remove the stock front section.
post #7 of 14 (permalink) Old 03-11-2019, 01:18 PM
Kenz's Avatar
IIRC getting it apart wasn't too hard on mine. Putting back together was a PITA. Especially since I used nuts and bolts off the manifolds.
What was the biggest hangup was where the clamp is on the small extension pipe, that joint was stuck together. Separating the exhaust at that location would give a lot more angle to remove and install it. I took it apart at the bolted flange in the middle, that makes it very tight to get in an out. Looking back I should have just cut the down pipes somewhere in the middle, and put it back together with band clamps. Would be kind of sloppy way to do it, but also have saved me a lot of time and drilling!
Another thing I did that helped... Matt posted in one of his threads that he cut down the two hangers a small amount before reinstall.That advice seemed to make it a bit easier to get back together
96 Cougar Sport - T45 Swapped
Kenz is offline
post #8 of 14 (permalink) Old 03-11-2019, 06:16 PM
On literally every single MN12 I have ever owned (that still had stock exhaust), I pulled the pipe back as far as it would go, then got out the cut-off wheel and cut the last inch or so off those bars that slide into the hanger, and never had an issue with them again.
post #9 of 14 (permalink) Old 03-12-2019, 08:57 AM Thread Starter
MadMikeyL that seems like what I need to do. The Smurf has no rust and I was amazed at how easily things came apart. I would never touch exhaust work up north because all the rust.
The exhaust slides nice and easy in those hangers, just won't come all the way out.
Kidd-7 is offline
post #10 of 14 (permalink) Old 03-12-2019, 02:50 PM
Oh yeah, I actually forgot I did that. I used the scissor jack to pull the assembly out the very first time but cut down the ends an inch or two to get it back in(and out later). I probably stole that technique from Mike too
Air2Mud likes this.
post #11 of 14 (permalink) Old 03-13-2019, 07:24 PM Thread Starter
I made some serious progress today before I lost light. I've got all 4 O2 sensors removed, the back 1/2 of the exhaust disco'd from the hanger at the diff and tied out the way & the 4 nuts holding the cats to the manifolds out. I've slid the Y-pipe back as far as I can, the drivers side cat is up against the body and can't get any more flex out of the pipes. Anyone familiar with the bracket mounted to the tranny that the exhaust hangers slide in? It looks like only 2 bolts hold that onto the tranny. There is a electrical connector that I would need to remove from the bracket and obviously support the tranny. Any other issues with removing that braket? I'll try to post pictures later once Dropbox catches up. I'll be back at it tomorrow.
Kidd-7 is offline
post #12 of 14 (permalink) Old 03-13-2019, 10:37 PM
Do you have a cut-off wheel or a sawzall? If so, just cut those hangers flush with the bracket while the exhaust is all the way back. If you don’t have a way to cut those on the car, then yes you will have to remove that bracket. If that is what you are trying to do, then put a jack under the trans pan with a block of wood to spread the load, then remove the one center nut for the trans mount, then the 2 outer bolts for the trans crossmember, then remove the 2 bolts holding that bracket to the trans, which also hold the trans mount.
post #13 of 14 (permalink) Old 03-15-2019, 12:31 PM Thread Starter
Exhaust is off. Will be replacing the crossmember bushings tonight and support the engine to remove the mounts tonight.
Kidd-7 is offline
post #14 of 14 (permalink) Old 03-16-2019, 06:05 PM Thread Starter
Got the tranny x member bushings replaced last night, engine lifted and supported today. Wrenched on some of the block bolts, but couldn't break them loose. Soaked with PB blaster and will revisit.
Kidd-7 is offline
Similar Threads
X Pipe & H Pipe TwistedT-Bird Exhaust 4 12-04-2014 08:02 PM
[email protected][email protected]*&#@&@*&!*&#[email protected]*[email protected]*#& 92CougLS Miscellaneous 0 02-14-2003 08:58 PM
H pipe X pipe Y pipe NO pipe? birdman Engine - 4.6L & 5.4L 5 02-12-2003 10:07 AM
X pipe vs h pipe J Series General Tech 14 01-23-2003 08:07 PM
X Pipe, H Pipe PimpTipp Engine - 4.6L & 5.4L 2 08-22-2002 01:42 PM
