Camber goes seriously negative when backing up..Normal or not? Please help! - TCCoA Forums
 3Likes
  • 1 Post By 392Bird
  • 2 Post By 392Bird
post #1 of 6 (permalink) Old 03-14-2019, 06:48 PM Thread Starter
Hello everyone. I noticed today that if I back into a park spot, then turn the car off and go around to the front of the car, looking at it dead on, you can tell that the tops of the tires are pointing inwards (negative camber). If I get back in the car, pull back out of the spot and drive forward a car length or so, then get back out, go look at the angle of the wheels, they are back to normal. (as far as how it looks). Camber looks ok.
I just had new tires put on (235-55-16 Kumho's). I don't have any pulling or any strange steering function or strange noises from the suspension. I do know I need to replace my junk engine mounts, and already have new solid rubber ones ready to go in. All of the suspension looks ok (tie rods, control arms, etc.). She rides smooth going down the road, and the factory struts still are in good shape.
Any idea if this is a problem or if this is normal for the MN12 tbird? I actually first noticed it when I was towing the car home after purchasing it (towing by the back wheels). The nose was pointed down and the camber had gone very negative while I watched it being towed.
Any thoughts?
Thanks everyone.
phils88tc is offline
post #2 of 6 (permalink) Old 03-14-2019, 07:06 PM
Upper Inner Control Arm Bushing.
Watch out for this issue: https://forums.tccoa.com/44-suspensi...-bushings.html
post #3 of 6 (permalink) Old 03-14-2019, 07:24 PM Thread Starter
Thank you for the quick reply. Are you saying that for my front suspension having this camber issue, you think it is the upper control arm bushings, and the link you posted should be checked out as well (it refers to the rear suspension)?
Just looking for clarification.
Phil
post #4 of 6 (permalink) Old 03-14-2019, 07:33 PM
392Bird's Avatar
Good to see you guys still providing good guidance to keep everyone safe.
Grog6 likes this.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #5 of 6 (permalink) Old 03-14-2019, 08:49 PM
I deserve that. I read rear, somehow.
I'm sorry; Front Suspension parts are in This Sticky: https://forums.tccoa.com/44-suspensi...t-numbers.html
First, I'd crawl under it and look it all over, and use a prybar to see what moves.
Suspect parts are:
- Front Strut Rod Bushings
- Rear Strut Rod Bushings
(both on front suspension, see Sticky referenced above)
- Loose lower inner control arm bolts
- Worn or missing control arm bushings
- extremely worn lower ball joints
You can work all of these with a short prybar, on jackstands, and the wheels off.
Pretty much, if it moves, it's toast; everything is supposed to be pushed together with some force with No play, or connected by thick rubber.
post #6 of 6 (permalink) Old 03-14-2019, 08:59 PM
392Bird's Avatar
That was meant as a complement, I miss read the earlier one also. LOL
MaddMartigan and Grog6 like this.
392Bird is offline
Similar Threads
Serious Negative camber after Spindle swap Help! phreakness Suspension 2 07-03-2007 06:57 PM
Serious Negative camber after Spindle swap Help! phreakness Engine - 4.6L & 5.4L 8 06-23-2007 07:30 AM
tach goes up...oil pressure goes down Audiobahnbird Engine - 4.6L & 5.4L 5 08-02-2005 12:33 AM
Negative Camber SoGATB Suspension 2 10-30-2003 10:14 PM
Backing up DVDs Kolenich Miscellaneous 13 10-22-2003 01:08 AM
