Replacing cruise control buttons - TCCoA Forums
post #1 of 5 (permalink) Old 04-06-2019, 03:38 PM Thread Starter
dukeofdexter's Avatar
Hey guys does this airbag just pop off so I can get to the buttons and detach my cruise control to switch it out?
dukeofdexter is offline
post #2 of 5 (permalink) Old 04-06-2019, 05:06 PM
Yes, there are two bolts on the sides to remove it.
Be really careful, as you don't want it to blow in your hands or face.
Unplug it, and set it aside; there's a shorting bar in the connector that makes it safer when unplugged.
If you're replacing them because the airbag blew, you also will want to replace the "Tray" it bolts to, as it will be distorted, and will make the horn blow.
post #3 of 5 (permalink) Old 04-06-2019, 06:34 PM Thread Starter
Just doin the cruise control buttons
post #4 of 5 (permalink) Old 04-06-2019, 07:02 PM
Woodman's Avatar
Disconnect battery before removing the airbag. Let the car sit with battery disconnected and light switch on to discharge the entire electrical system to make sure nothing to set the bag off.
Woodman is offline
post #5 of 5 (permalink) Old 04-07-2019, 09:15 AM Thread Starter
That wasnt mentioned but of course LOL
Similar Threads
replacing cruise control buttons... 96_4.6_MN12 Interior 14 12-14-2009 07:37 PM
Cruise control buttons azreael344 Interior 13 11-15-2003 12:55 AM
cruise control buttons 94ONAIR Interior 1 04-15-2003 07:11 AM
cruise control buttons Trick Bird Interior 5 02-15-2003 04:06 PM
