Chemical smell in cabin - TCCoA Forums
post #1 of 3 (permalink) Old 04-25-2019, 12:01 PM Thread Starter
While replacing my motor mounts the smurf sat in the driveway for about 5 weeks. Upon re-entry to drive it smelled musty in there. Figured it was from the humidity and being closed up for so long. The musty has since dissipated, but I have a chemical smell in the mornings. Opening the windows or vents / fan dissipates the smell fairly quickly. The carpet is not moist, the a/c blows cold, coolant level & color is good, Temp gauge does not bounce like it would if an air bubble was in the system. Any thoughts? I can't place the smell. She's a 96 Cougar 4.6 stock. Thanks.
Kidd-7 is offline
post #2 of 3 (permalink) Old 04-25-2019, 09:26 PM
Have you cleaned the vinyl interior lately? Could be residue from whatever product you used and now the humidity is bringing it out.
FordMan77 is offline
post #3 of 3 (permalink) Old 05-02-2019, 09:28 PM
Try using one of the vent cleaning products - such as the one by Interdynamics IDQ A/C & Heater Duct Cleaner or Armor All at Advanced Auto Parts.
Older cars don't have cabin air filters - so all that stuff accumulates at the bottom of the vent housing and gives that musty smell- especially when it's humid. The vent cleaners get sprayed into the intakes (and the vents) - follow directions - and sanitize the mold stuff. It works quite well. Used a couple time on my '96 TBird - end of odors.
Consultant is offline
Similar Threads
Coolant Chemical Flush. Burner1515 General Tech 17 10-17-2009 06:50 AM
Best chemical to remove paint? RacerXHG Exterior 12 05-02-2005 03:05 PM
The smell of gas... EVIL! (gas smell in car...) Richelieu Engine - 4.6L & 5.4L 8 12-13-2004 10:20 PM
Chemical Paint Strippers on Urethane? SanDiegoLXBird Exterior 7 10-26-2004 06:43 PM
Fuel Injector Servicing-Non Chemical PCD General Tech 16 01-29-2004 09:40 AM
