AC comp clutch cycling pressure switch? - TCCoA Forums
post #1 of 2 (permalink) Old 06-08-2019, 08:18 PM Thread Starter
Air2Mud's Avatar
I'm about to add some refrigerant to my 89 T'ird A/C.
Can I just disconnect/remove the pressure switch sitting atop the accumulator low pressure port while I add refrigerant in what I would call the normal way then reinstall it? Or is there some magic this switch controls that I'm not aware of? Thanks for any clues or advice.
MDW
Air2Mud is offline
post #2 of 2 (permalink) Old 06-08-2019, 09:12 PM
I don't know how the 89s are with R12 but on the 94+ R134a cars, there's a dedicated charging port next to the cycling switch. In either case, there should be a check valve under each which will prevent refrigerant loss if caps/switches are removed.
Similar Threads
ac compressor short cycling. have readings.. DIRTYMC Engine - 4.6L & 5.4L 23 06-28-2014 02:12 PM
1997 A/C cycling switch theterminator93 Wanted 2 07-24-2009 11:12 PM
'97 A/C Cycling Switch?? Pearl97LXSPORT General Tech 2 10-10-2008 05:04 PM
AC Cycling switch Bad-Hoschy Interior 7 06-16-2008 07:58 PM
AC compressor keeps spinning, not cycling = no cold air. L33TX43RT Engine - 5.0L & 5.8L 6 04-30-2004 05:27 AM
