Turn signal return won't - TCCoA Forums
post #1 of 6 (permalink) Old 10-01-2019, 05:52 PM Thread Starter
kny
I have a low mileage '96 TB LX V6. Two years ago I had a mechanic replace the Multi Function Switch on the steering column. Since then the lever has always been a little stiff when activating it for a left turn, and in the last couple of months, sometimes it just doesn't travel all the way to turn on. Now the turn signal lever doesn't return either on a left or right turn, and I have to manually turn it off. Are there replaceable springs in the switch, or will the entire switch have to be replaced again?
Ken
kny is offline
post #2 of 6 (permalink) Old 10-01-2019, 07:08 PM
Kenz's Avatar
I don't have an answer to your question. However I installed an aftermarket multi function switch in my Cougar, and the switch has a noticeably less smooth operation than the factory one. The Standard Motor Product brand I installed feels a lot less quality; will not be surprised if it doesn't last very long.
It will be getting replaced with an OEM Motorcraft brand.
96 Cougar Sport - T45 Swapped
Kenz is offline
post #3 of 6 (permalink) Old 10-02-2019, 07:49 AM
T6Rocket's Avatar
^^Actually, you did answer his question! I agree, stick a new Motorcraft in there.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #4 of 6 (permalink) Old 10-02-2019, 11:52 AM
It's pretty easy to disassemble, clean, and reassemble the stock switch; it only takes about a half hour.
There's a bit of slop in the mounting bolts; it could be interfering with the steering column cover.
You will have to take the cover off to look at it.
See if it works with the cover off.
post #5 of 6 (permalink) Old 10-02-2019, 05:55 PM Thread Starter
kny
The switch that the mechanic installed is a BWD-S3216, and partstech.com shows that has a 3 year 36,000 warranty - surprising. I'm going to call the mechanic and ask him if that's correct. I've been reading forum posts about replacing it yourself, and am not sure. One thing - how do you remove the tilt lever?
kny is offline
post #6 of 6 (permalink) Old 10-03-2019, 07:58 AM
T6Rocket's Avatar
IIRC, you don't remove the tilt lever. You do have to remove the plastics, which can be tedious. May have to remove the ignition switch to get them all the way off. Basically, if something is even partially blocking another thing, it has to come off. If you try to sneak it past, it might break.
Al
Previous Fords:
T6Rocket is offline
Similar Threads
Wheel won't return; stiff trinogt Suspension 16 05-13-2009 08:02 PM
need help converting mustang non return fuel rails into return style blown96bird Engine - 4.6L & 5.4L 2 12-14-2008 03:50 PM
Fuel rail adapter, convert non-return to return... unity Engine - 4.6L & 5.4L 7 08-29-2008 05:30 PM
passenger seat will recline but won't return ThunderB Interior 6 06-18-2003 11:30 AM
Alternatively Flashing Turn Signal Ashish Exterior 5 07-23-2002 10:12 PM
