It's not a ford but i need help please!! - TCCoA Forums
post #1 of 13 (permalink) Old 12-03-2003, 10:20 PM Thread Starter
toofast4u's Avatar
Send a message via Yahoo to toofast4u
I have a 86 jeep wagoneer It will not start it stoped going down the road and will not start. The battery is up and was not dead when it stoped the headlights work but the radio don't and the blower on the heater don't run. I tried to jump the starter siolniod but nothing happens. Could this be a volt regaltor?? What all does the volt reg control? Or could it be the ingetnion moulde?/ Please help people thanks
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #2 of 13 (permalink) Old 12-04-2003, 07:18 AM
On Probation
blown96bird's Avatar
It sounds like that one of the fuzeable links blew and there is probly more than one. If one blew then you need to find out why It is possiable that it just got old and a few wire broke from chais or engine movement over the years. I had the same thing happen to my oldsmobile
blown96bird is offline
post #3 of 13 (permalink) Old 12-04-2003, 08:29 AM
RGR
Originally posted by blown96bird
Allen Supercharger, 38# injectors, 75mm throttlebody, 90mm lightning mass air meeter, lightning air charge temp sensor, Griffin HP radiator, A.R.T stainless steel exhaust system, Dennis driveshaft, 3.73 punkin, custom programed computer...
How do you like that Allen SC unit man???
I saw an article on it when it came out, looked schweeeet!
RGR is offline
post #4 of 13 (permalink) Old 12-04-2003, 08:33 AM
On Probation
It is very nice I have modified mine quite snifigantly and am making much more hp than a standard allen kit.
post #5 of 13 (permalink) Old 12-04-2003, 08:42 AM
RGR
nice! got a link to the mods or a post covering it?
Inquiring minds want to know!
RGR is offline
post #6 of 13 (permalink) Old 12-04-2003, 11:03 AM
On Probation
my improvements
my allen improvements
post #7 of 13 (permalink) Old 12-04-2003, 12:29 PM
blown96bird-
What numbers are you making?
What about the quarter mile?
-Brian
TbirdJLcustom is offline
post #8 of 13 (permalink) Old 12-04-2003, 02:47 PM
5.0 Chero's Avatar
LOOKS LIKE THIS THREAD WAS JACKED!
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #9 of 13 (permalink) Old 12-04-2003, 03:08 PM
On Probation
I think that I am making 350 rwhp and 390 rw tq and I am running 12.85 at 106 mph.
post #10 of 13 (permalink) Old 12-05-2003, 08:43 AM
Kolenich's Avatar
Sound like the joy of 20 year old wiring. You will probably need to get a Voltmeter and check the wiring under the dash. I believe it would be and under the dash problem because your accessories dont work. If certain electrical circuts are broke the engine wont run either. You will probably need to get a manual to tell which wires are which and were they go to.
Good luck
Karl
Kolenich is offline
post #11 of 13 (permalink) Old 12-05-2003, 09:30 AM
RGR
Unhappy
Sorry!
RGR is offline
post #12 of 13 (permalink) Old 12-05-2003, 10:14 PM Thread Starter
toofast4u's Avatar
Sure was!!! I got it fixed thanks
post #13 of 13 (permalink) Old 12-07-2003, 03:54 AM
So your Jeep is running all right now? What was the problem? Ignition switch?
Steve
S_Mazza is offline
