rpm dropping - TCCoA Forums
post #1 of 6 (permalink) Old 12-05-2003, 03:59 PM Thread Starter
Send a message via AIM to toymrj Send a message via Yahoo to toymrj
rpm dropping
it mostly does it when the car is cold but still does it sometimes when car is warmed up but not too often. when i press the gas down the car pretty much buckles or should i say the rpm drop down like 500 (somewhere between that 300-500rpms) then a sec later it jumps up then the car goes but it just buckles for a sec. i pulled a code that the egr solenoid was stuck in the wide open position. so dont even if that is what is causing the problem and just changed my spark plug wires and spark plugs and cleaned the maf. any suggestions are great?
toymrj is offline
post #2 of 6 (permalink) Old 12-08-2003, 10:41 AM
Trumpeter Extraordinaire
IronChopz's Avatar
Which code exactly did you get? If the code indicates the EGR solenoid is stuck open, it could be a faulty EGR solenoid (~$32). It's a relatively easy replacement, and has a vacuum connection on it. I was able to change the solenoid in about ten minutes, despite not being able to see the bolts directly.
It's part #4 in this diagram...
IronChopz is offline
post #3 of 6 (permalink) Old 12-08-2003, 04:48 PM Thread Starter
yea thats what i thought but the thing is advanced auto and autozone did not have the part.
toymrj is offline
post #4 of 6 (permalink) Old 12-08-2003, 06:58 PM
IronChopz's Avatar
Very true. After finding out those places don't carry that part, I got a replacement from the dealership.
post #5 of 6 (permalink) Old 12-08-2003, 08:35 PM Thread Starter
how much was it from the dealer. the $32 dollars u said it was right.
toymrj is offline
post #6 of 6 (permalink) Old 12-08-2003, 10:43 PM
I had the same exact problem on our family's '94 Tbird. When it is cold and you give it gas, RPMS drop, the car stumbled, then a second later rpms increase and its fine. Only had the problem when accelerating from a stop. I replaced the MAF even though I cleaned it, and the problem never came back.
Annihilator is offline
