Right rear problem! - TCCoA Forums
post #1 of 6 (permalink) Old 12-08-2003, 09:47 AM Thread Starter
Right rear problem!
5 months ago I had to take the right rear suspension off to fix 2 broken lugs. Ever since then I have had trouble keeping the stud lock bolt to stay on, and my ABS light has stayed on (but that is another post). I have bought a new bolt from Ford and tightened it down with all my dads weight (and he should have been enough), but on my way back across the state the other night, it came loose again causing a sound as if the tire was comming off. I have one more new bolt to put on, should I try some blue lock tight to help keep it on, or is it a bigger problem?
post #2 of 6 (permalink) Old 12-08-2003, 10:31 AM
Trumpeter Extraordinaire
IronChopz's Avatar
Do you mean part #6 in this drawing? If so, it must get tightened to 188-254 Lb-ft. I have no idea why you couldn't use threadlock, but I haven't found anything about using threadlock in the service manual or tech articles....
Edit corrected typographical/grammatical error...
IronChopz is offline
post #3 of 6 (permalink) Old 12-08-2003, 11:06 AM
tbirdbrain's Avatar
There is an old trick to keep those pesky axle nuts loosening. First take a new nut
and torque it to factory spec (250lb/ft). Use an old nut and thread it on the axle up to
the new nut then tighten it to 100lb/ft.
I have had this problem also. The use of the second nut acts as a ‘jam’ nut and
won’t allow the primary nut to loosen. In some circumstances it seems that there
can be a sympathetic resonance in the axle/hub assembly which given time
can cause this to happen.
Hope that helps
tbirdbrain is offline
post #4 of 6 (permalink) Old 12-09-2003, 12:33 PM Thread Starter
I tried to tighten the bolt, it was tight. I now have no clue to what is wrong. I makes a popping noise when I turn kinda how it did when the bolt was loose. Any suggestions.
post #5 of 6 (permalink) Old 12-09-2003, 01:15 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Trac Loc clutches perhaps?
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #6 of 6 (permalink) Old 12-13-2003, 01:28 PM
Old_coot's Avatar
Send a message via Yahoo to Old_coot
Or CV joint possibly?????
Old_coot is offline
