5.0L MAF, will it work. - TCCoA Forums
post #1 of 9 (permalink) Old 12-08-2003, 07:15 PM Thread Starter
I'm looking for a stock MAF from a 5.0L bird or cat. This is for a friends 88 GT MAF conversion. I'm sure that the 5.0l's have 19lb injectors, but do the 3.8l N/A birds have 19's also? And...are the electronics the same on all the models? I was thinking yes, and the ECU controls the ratio not the MAF meter. Let me know guys, my friend needs to get this car running.
fastsc92 is offline
post #2 of 9 (permalink) Old 12-08-2003, 07:55 PM
Refrigerator Raider Hater
GreenBird's Avatar
Yes, but a MAF configured for a 8 cyl w/ 19s does not equal a MAF for a 6 cyl with 19s.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 9 (permalink) Old 12-08-2003, 08:02 PM Thread Starter
are you sure its configured that way? I thought the ECM does the calibration. But the 5.0l MAF will work for a stang right?
fastsc92 is offline
post #4 of 9 (permalink) Old 12-09-2003, 04:26 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
transfer functions for a 19lb v8 are different than a 19lb v6. Think about it, the other maf has to calibrate and meter air flow for two more cylinders.
-Thomas
Thomas is offline
post #5 of 9 (permalink) Old 12-09-2003, 06:20 AM
5.0 Chero's Avatar
It depends on what the part number on the sensor is I am running a v6 tbird 55mm mass air flow on my ranchero right and have been now for a year and a half now ill check the part number and let you know i think its F1Z- as long as the 3 didgt is a z you will be ok! the first v6 used mustang 5.0 55m mass air meters the later the later 70mm wont work different transfer functions.
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #6 of 9 (permalink) Old 12-09-2003, 01:38 PM Thread Starter
but as long as i get a MAF for a 5.0 bird...it should work with a stang..right?
fastsc92 is offline
post #7 of 9 (permalink) Old 12-09-2003, 01:56 PM
Uber Luber
Thomas's Avatar
Should work, yes. I don't know if it makes a difference wether it's HO or not, wouldn't think so.
-Thomas
Thomas is offline
post #8 of 9 (permalink) Old 12-09-2003, 02:20 PM
5.0 Chero's Avatar
mass air 5.0 birds are H.Os and as i said as long as it has a Z and not a S as the third didgt in the part number you will be fine!
THE PYL !
86 F250 Diesel 4x4
GONE 89 Aerostar
1996 Exploder
post #9 of 9 (permalink) Old 12-09-2003, 02:22 PM
Uber Luber
Thomas's Avatar
Oops my bad, sorry.
-Thomas
Thomas is offline
