robershaw autozone thermostat owners beware - TCCoA Forums
post #1 of 19 (permalink) Old 12-09-2003, 09:00 PM Thread Starter
On Probation
blown96bird's Avatar
I had to replace the thermostat in my bird it stuck partil shut and caused the car to get warm but I caught it before it got past 2/3 on the gauge. I pulled it out and noticed that around 3 of the bras rivits were cracks. I talked to them at orriels and they said that they stoped carring them because of the high rate of failures. I went ahead and installed a new failsafe unit for my car. I also did the thermostat mod which is drilling 1 1/8 of a inch hole in the thermostat. I notice on the old stat woluld notice the temp going down at 194 and close at 172. The new stat with the mod temp would start going down at 188 and close at 176 providing much less tempeture swings. The temp swings on the old stats were done 2 weeks before it failed.
blown96bird is offline
post #2 of 19 (permalink) Old 12-09-2003, 10:32 PM
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
Thanks for the warning.
PJ
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
post #3 of 19 (permalink) Old 12-10-2003, 12:43 AM
Aaron_T's Avatar
what's this "mod" your talking about? Is it more of a saftey thing?
Luckily no Autozones here.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #4 of 19 (permalink) Old 12-10-2003, 06:14 AM
Good luck if you can still even find Robert Shaw thermostats. When I went looking for my 180 I couldn't find them anywhere.
AutoZone doesn't carry them anymore and I couldn't find them online. It seemed like they just disappeared from the planet. I even went to their web site and they don’t mention automotive thermostats at all.
69 F100 LWB w/460 Engine
post #5 of 19 (permalink) Old 12-10-2003, 08:21 AM
The Great Obucina's Avatar
do you have a recomendation for a 180* 'stat to get instead? Ive had a Rob Shaw unit for quite a while and the cooling seems kinda funky. I guess its time to add to the list.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #6 of 19 (permalink) Old 12-10-2003, 08:28 AM
I ended up using the Ford OEM for a Lightning. It is supposed to be 180, but I've heard from some Lightning owners that it is a little higher. But I haven't been able to confirm it one way or the other, so who knows.
There are probably better thermostats out there, but I try to stay OEM if possible.
But that's just me.
post #7 of 19 (permalink) Old 12-10-2003, 11:08 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Looks like we gotta find a reliable source of 180* stats now since the Robert Shaw used to be the recommended one...
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #9 of 19 (permalink) Old 12-10-2003, 11:30 AM
Sheepish
AverageJoe's Avatar
Originally posted by JR Tigerstar
When I had the head swap done back in April '03 I used Fords thermostat.
Part # XL3Z-8575-AA, $7.28. The box was labled 180*.
Sounds like we have a winner!
post #10 of 19 (permalink) Old 12-10-2003, 01:35 PM
i got mine from napa, doesn't say who made it though?
XR7kid is offline
post #11 of 19 (permalink) Old 12-10-2003, 01:44 PM
Fry Rice Specialist
Casper's Avatar
i have one from stant.
CarDomain Page
Casper is offline
post #12 of 19 (permalink) Old 12-10-2003, 03:30 PM
stant here also.
Rich95XR7 is offline
post #13 of 19 (permalink) Old 12-10-2003, 03:51 PM
jk69cat's Avatar
after spending ten years in ford dealers and seeing what ones work and dont, no aftermarket really works as well as a factory ford tstat. dont know why, but most of my outside only use the factory units as well. has something to do with inproper temp ranges and such.
jk69cat is offline
post #14 of 19 (permalink) Old 12-10-2003, 04:10 PM
Fry Rice Specialist
Casper's Avatar
even thought i'm using the stant now with the original temp range(195) my temp gauge still show lower than normal and fluctuated quit a bit......
CarDomain Page
Casper is offline
post #15 of 19 (permalink) Old 12-19-2003, 10:37 AM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
I am also using a 180* Stant T-Stat for $5.68 with no problems.
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #16 of 19 (permalink) Old 12-19-2003, 12:22 PM
Mine is a super stant 180* from NAPA. Didn't keep the part #. Sorry.
Grasshopper is offline
post #17 of 19 (permalink) Old 12-20-2003, 12:57 AM
I'm also using a 180* Stant without any problems. My temp stays pretty steady between 185*-195*.
-Rod
post #18 of 19 (permalink) Old 12-20-2003, 01:51 AM
MaleWhore
smokymance's Avatar
anyone has any info on this t-stat mod..??
smokymance is offline
post #19 of 19 (permalink) Old 12-20-2003, 04:15 AM
the mod is simply drilling a hole (1/8 i think) to allow some flow like the oem does, except the stocker has a check ball.
RyanG is offline
