The Bad Bird is under the Knife!!! - TCCoA Forums
post #1 of 17 (permalink) Old 12-10-2003, 10:29 PM Thread Starter
Well after 100,000 mile on the OEM parts I am getting alllot of the Maint stuff done I hate spending money on!!! SInce they are going to drop the cradle to put he manifolds back on might as well replace all the stuff associated with it,
New Shock/Struts
A-arms
The cracked header syndrone(Will melt the jbas down and send them to JBA
Brake Job, Original rear shoes replaced
Front end alignment Never had one done
New Drive Belt
Tranny flush
Radiator Leak-Just popped up.
I know allot of this can be done in the garage but with two bum Elbows and neck makes it hard to turn a wrench.
I think we should start a class action suit against JBA for pain and suffering
I guess its not all bad I did manage to pick up a Zex kit for 200 bucks a small shot will help ease the pain
mazda6 Sport- 06
100hp worth of Stickers coming soon
Blake-vortech is offline
post #2 of 17 (permalink) Old 12-10-2003, 11:03 PM
On Probation
blown96bird's Avatar
Hey blake go over to blue oval news and take a look at the 3 valve 2005 mustang gt motor and take a look at the exhaust manifold. It is cast iron but it is like a header. Each runner has its own runner to a collector. It would be great if they could be used on a bird with header flow but with out the problems. I am doing some 100000 mataince also. I just purchaced new upper controol arms. In a couple of weeks I will get new lower controol arms and tierod ends, strut rod bushings. I am going to replace my stock overdrive servo with the upgraded one and flush the trany.
blown96bird is offline
post #3 of 17 (permalink) Old 12-11-2003, 10:30 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
So how much are you going to wind up dropping on this maintainence endeavor Blake?
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #4 of 17 (permalink) Old 12-11-2003, 04:49 PM Thread Starter
Probably close to a 1000.00 when it all over
mazda6 Sport- 06
post #5 of 17 (permalink) Old 12-11-2003, 09:05 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
thats not too bad you puting drags shocks or just some regular stock stuff , if you dont mind me asking how much boost are you running Pm me if you dont want to post it on here .
Jurgen
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
post #6 of 17 (permalink) Old 12-11-2003, 09:12 PM Thread Starter
On they dyno when Jw tuned it i made about 14lbs @6200RPM. It shifts at 6k so probably 12 or so.
bc
mazda6 Sport- 06
post #7 of 17 (permalink) Old 12-12-2003, 11:32 AM
(Will melt the jbas down and send them to JBA)
Please don't do that... they will probably use the metal to make more headers to sell to some other unsuspecting soul...
Egads, man $1000 on maintanence after only seven years????... maybe you oughtta melt the car down and send it back to Ford
I can relate, though.. I no sooner started sinking money into modding the '96 when little (and not so little) things started to break, or need replacement on both the '96 and '95.. While Scott is "playing" with GB, up in Atlanta... I'm driving around town with a very noisy power steering pump... guess I better give Dan a call..
I really am glad to hear you're taking care of that "regular" stuff... I mean I may end up in your class next year at SSHS 4 and I'll feel a lot safer driving along beside you at 115 mph...
96 GoldBird
N/A:
96 GoldBird is offline
post #8 of 17 (permalink) Old 12-12-2003, 11:40 AM
JustinH's Avatar
You might want to look into a 03 cobra radiator, this would be the time to get one before the price goes through the roof.
JH
JustinH is offline
post #9 of 17 (permalink) Old 12-12-2003, 11:46 AM
JH
Have you checked the new FRPP catalogue... they are listed in there, now.. I didn't check the price, but someone told me that they already raised them from what I paid..
That is a real sweet upgrade, though if the price is still low... gotta get the shroud/fan unit, too...
96 GoldBird
N/A:
post #10 of 17 (permalink) Old 12-12-2003, 11:47 AM
JustinH's Avatar
no, i got my catalog from dan, but its sitting in my house, I haven't looked at it yet.
That figures man, I was just going to order one for myself for the new car.
JH
JustinH is offline
post #11 of 17 (permalink) Old 12-13-2003, 02:09 PM
I have a noisy PS pump too. Though I do not mind it too much as it sounds like Tim,s blower at idle!. It is on the replacement list of parts for when the other engine is installed. Will still have the same noise because it will actually have the a blower on it then!
Cam94 is offline
post #12 of 17 (permalink) Old 12-17-2003, 10:35 PM Thread Starter
BAd Bird is back on the road. Man I didn't ralize how rough the ride was. Feels pretty good on the way home. Still have to get the ART exhaust tweaked to mate up to the manifold on the passanger side. Its got a small leak at the flange. I guess when I had the x pipe welded the jba hit at a slightly differnet angle. They ended up putting a bung on the drivers side manifold for the egr using some type of lime solution to cure it after is was welded into the cast manifold. The place that did it does a bunch of NHRA stuff and probably the best metal man in town, als.o found out my ps pump has a leak and one of my tranny cooler lines is ready to blow.
So heres a run down
New Belt installed (If you ever tried to put a belt on my car no small task extrmely tight
New front Brakes
moog A-arms
Header swap
shock/struts
4- wheel alignment
A bunch of misc stuff
mazda6 Sport- 06
post #13 of 17 (permalink) Old 12-17-2003, 10:44 PM
New front Brakes
moog A-arms
shock/struts
4- wheel alignment
Bet she feels like a new ride...
They really do appreciate that attention. It's like they are a living breating thing.. I guess they are...
What shock/strut combo did you end up using??
and what did do about headers???
96 GoldBird
N/A:
post #14 of 17 (permalink) Old 12-17-2003, 10:47 PM
Sheepish
AverageJoe's Avatar
Wow, sounds like your car was a tickin bomb Blake, how much did it lighten your pocket after all that?
post #15 of 17 (permalink) Old 12-18-2003, 03:34 PM Thread Starter
Went with the Tockico blues compromise between the Bilstiens and the KYBs. I ported a set of manifolds I got from DanU in Dallas. It will probably kill my 60fts with new struts on the front. Stuff wears out at 100,000 miles. The rear-end is whing so Iam sure the pour Auburn I put in 6 years ago will need to be replaced along with the gears. It has been heavly abused.
mazda6 Sport- 06
post #16 of 17 (permalink) Old 12-18-2003, 04:17 PM
And she will rise from the ashes.. reborn... renewed in strength...
I am beefing up my suspension, too.. bigger bars, stiffer springs.. It'll kill my launch, but I'm looking down the road, and when I add power, I want to be able to keep her on the road headed in the right direction... I also love to take corners at speed and run those banked off ramps to the "S" turns...
96 GoldBird
N/A:
post #17 of 17 (permalink) Old 12-18-2003, 10:28 PM Thread Starter
Got the exhaust leak fixed today the mufler man had to tweak it. Its amazing how quiet the cari s without the header leak, I guess you get used to it between the suspension stuff and the leak fixed its like driving a brand new car. The shop asked me if I wanted the headers back I told him to pitch them in the trash. The passanger side was destroyed it actually was forming a big hole from the stress fracture.
mazda6 Sport- 06
