engine missing - TCCoA Forums
post #1 of 13 (permalink) Old 12-17-2003, 09:52 PM Thread Starter
MaleWhore
smokymance's Avatar
engine missing
a slight problem that happens to me that bothers me once in a while. this doesnt happen all the time, and i have no idea why. well, lets say im doing 40mph and i need to accelerate, i push down the pedal a little bit, just so i get it to get moving, maybe enought to get it to downshift, but once in a while, the car shakes, or hesitates kinda, like its not getting enough gas or something, thats what i think it is but i might be wrong. i did get new wires, plugs, coil packs...so its not those...i have cleaned the MAF(like 2 months ago, might need to do that again), and i have changed the fuel filter...what do u guys think is the problem...i throw 89 octane on it...
smokymance is offline
post #2 of 13 (permalink) Old 12-17-2003, 09:54 PM
Mine did that exact same thing... I changed the plugs, wires, and fuel filter all at once and it hasnt dont it since. I run 87 octane gas.
weswing04 is offline
post #3 of 13 (permalink) Old 12-17-2003, 10:12 PM Thread Starter
MaleWhore
smokymance's Avatar
what do u do if it still does it afterwards...it didnt do it right after i changed all that, but now it back
post #4 of 13 (permalink) Old 12-18-2003, 12:45 AM
i dunno, but i had the same problem in my crown vic winter beater. replaced plugs and wires and it seemed to stop for awhile. that is until i lost 3rd and 4th gear about 2 weeks later. not sure if the two were related or not...
ty
Current: K&N panel, FR pulleys, B&M shift kit and tranny cooler, true dual stainless w/ flowmasters, drchip, '02 GT MAF, cold plugs, 180' tstat, FRPP 9mm wires, 235/45ZR17 firehawk SZ50ep tires on chrome lincoln ls rims.Johnny's braces, bilsteins, FRPP pumpkin, MMX driveshaft
Comming Soon: Marauder tc
tyson is offline
post #5 of 13 (permalink) Old 12-18-2003, 10:07 AM Thread Starter
MaleWhore
smokymance's Avatar
nobody has a clue what the problem could be?
post #6 of 13 (permalink) Old 12-23-2003, 07:35 PM
ITT-BIRD's Avatar
OK to kinda put myself on the "plank" ... im going to give my opinion ...
Are you sure its a miss? does it throw a code. might try to search the tranny fourums. I had/have a problem with my 87' crown vic with 210,000 original hard miles on engine/tranny .... the torgue convertor is wore to he11. When i lightly try to accel, the tranny wont downshift right away and will kinda act as if i was in a standard taking off in 3rd, the bogging down type symptoms. Maybe tq is not allowing to downshift or come from tq lockup. I would floor the old vic and wouldnt miss a beat. Did j-mod yet? last fluid change?
Which kinda sounded like tysons probs
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #7 of 13 (permalink) Old 12-28-2003, 12:29 AM Thread Starter
MaleWhore
smokymance's Avatar
that could be it too....it does bogg when i get on it and it doesnt rev up...the last fluid change was a little bit ago...i got the car in april and changed the fluid at 84k...then again at like 90...so i know its not that...trany is stock...no j mod or whatever...what do i do...i cant afford a new tranny.....
post #8 of 13 (permalink) Old 12-28-2003, 12:31 AM Thread Starter
MaleWhore
smokymance's Avatar
oh yeah one more thing...it never happens at colder weather or cold air out side...like when i always come home late at like 2 am, it never happens...dont know if that even has to do with it
post #9 of 13 (permalink) Old 12-28-2003, 12:51 AM
ITT-BIRD's Avatar
Hmm... been doing some more thinking ... mine has been doing similar probs. everytime i think about trying it, the prob wont surface .... but i havent changed my fluid in about 15k miles ... i have 100k on it. Maybe my/our torque convertor starting to wear.
ITT-BIRD is offline
post #10 of 13 (permalink) Old 12-28-2003, 12:55 AM Thread Starter
MaleWhore
smokymance's Avatar
so basicly a new TPS wont help...it is worth changing????
post #11 of 13 (permalink) Old 12-28-2003, 02:03 AM
ITT-BIRD's Avatar
Out of my 2 yrs of doing driveability at the dealership... ive changed one throttle position sensor and it was on a late model straight six 300 ... guy i did alot of work with, 20yr veteran, says that the new tps very seldom go out ... did i say very. But is very easy to test if you know someone that do it on their lunch break ... koeo at idle should read approx. 1v and gradually climb to approx. 5v.
only other sensor that i would think of is the MLPS but it causes other probs .. such as improper shifting into neutral or up and downshifting probs.
ITT-BIRD is offline
post #12 of 13 (permalink) Old 12-28-2003, 10:03 AM Thread Starter
MaleWhore
smokymance's Avatar
i guess i have to save up for a new converter...
post #13 of 13 (permalink) Old 12-28-2003, 04:46 PM
ITT-BIRD's Avatar
seen in the for sale fourom a brand new mark tq and flexplate for $200
I would get it if i hadnt spend so much for christmas.
ITT-BIRD is offline
