worrisome vibration... - TCCoA Forums
post #1 of 3 (permalink) Old 12-20-2003, 12:31 PM Thread Starter
lately i have been noticing a vibration in my car. It only occurs occasionally. I can sometimes make it happen by going up a hill at about 30 mph/1100 rpm.. and barely pushing on the gas. just pushing the gas enough to maintain the 30/1100 range. The vibration almost feels like i am running over those multiple speed bumps before a stop sign. it feels like it is vibrating from the backend. although i can make it do it, it has happened while on the highway or while accelerating. any thoughts of what it could be? it worries me a little. any help is greatly appreciated..
seth
[email protected]=iii=<| is offline
post #2 of 3 (permalink) Old 12-20-2003, 01:02 PM
JustinH's Avatar
If it feels like running over a washboard in the road, then its probably torque converter shudder caused by transmission fluid breakdown.
Change your fluid over to Mercon V (make sure you drain the transmission and refill as per the tccoa tech article)
That usually solves the problem.
JH
JustinH is offline
post #3 of 3 (permalink) Old 12-30-2003, 08:21 PM
I would also add a tranny cooler. You don't want to forget to drain the t/c either.
thndrchiken is offline
