Moron brake help quick! - TCCoA Forums
post #1 of 9 (permalink) Old 12-26-2003, 01:10 PM Thread Starter
OK, I'm trying to put these damn new rotors on. I see i've gotta take the caliper off, but how? The big bolts, or the Torx crap?
Either way, those sonsa*****es are on tight. Don't tell me they're reverse threaded.
Vegeta99 is offline
post #2 of 9 (permalink) Old 12-26-2003, 01:22 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
The torx ones will take off the calipers themselves, but leave the brackets behind.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #3 of 9 (permalink) Old 12-26-2003, 01:31 PM Thread Starter
Will the brackets be in the way of the rotor for removal? It looks like they will be...
Vegeta99 is offline
post #4 of 9 (permalink) Old 12-26-2003, 01:45 PM
Sheepish
AverageJoe's Avatar
As far as I know they will be.
post #5 of 9 (permalink) Old 12-26-2003, 02:01 PM
jk69cat's Avatar
yes and yes, the torx need to come out to remove the caliper and the other 2 need to come out to remove the brackets so you can get the rotors off,
jk69cat is offline
post #6 of 9 (permalink) Old 12-26-2003, 02:23 PM
02 Explorer Pioneer
timb's Avatar
I beg to differ. All you need to do is take off the hex bolts and remove the caliper and bracket as one unit. It isn't necesary to remove the torx if you aren't replacing the calipers
Birdless
timb is offline
post #7 of 9 (permalink) Old 12-26-2003, 02:52 PM
jk69cat's Avatar
true, i figured hes changing pads too.
jk69cat is offline
post #8 of 9 (permalink) Old 12-26-2003, 03:07 PM
Jedi Master
mn12xr7's Avatar
welll when changing rotors, its recommended to change the pads as well
-Orlando
mn12xr7 is offline
post #9 of 9 (permalink) Old 12-27-2003, 01:36 AM Thread Starter
yeah, well, I can't afford pads at this time :/
I'm broke, and I'm sick of the shaking from bent as hell rotors
Oh, BTW, after breaking 2 ratchets on the bolts, my parents decided to give in and pay a mechanic to do it :/
Vegeta99 is offline
