quickness - TCCoA Forums
post #1 of 22 (permalink) Old 12-29-2003, 09:19 AM Thread Starter
quickness
hi all , just bought a 97 bird 4.6 v8 with 36000 miles on it , feels kind of sluggish off the line , would a chip take care of that . other than that what a great ride . thanks
judge is offline
post #2 of 22 (permalink) Old 12-29-2003, 10:53 AM
Refrigerator Raider Hater
GreenBird's Avatar
Some shorter (numerically higher) gears, or a higher stall TC would help. A chip would help also, but the gears or TC would be most effective.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 22 (permalink) Old 12-29-2003, 01:15 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Greenbird took the words out of my mouth. The gears and TC will make it feel like a totally different car and the chip will only accent that.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #4 of 22 (permalink) Old 12-29-2003, 05:18 PM Thread Starter
thanks for the reply . so if i go with maybe 355 gears that will make a nice difference?and do i need anything else besides a cooler and speedo . also , what would figure a shop would charge for something like that ? thanks . any other tips for this vehicle is very welcome.
judge is offline
post #5 of 22 (permalink) Old 12-29-2003, 06:11 PM
Sheepish
AverageJoe's Avatar
3.55s will make a nice difference in town and still be good for highway.
3.73s will make a nicer difference both in town and on the highway, but not the best choice if you do a lot of highway travel.
4.10s if you want to get really hairy in town and do very little highway duty.
You can expect generally $300-500 labor for a gear install with the pumpkin in the car due to the fact that they have to remove the pumpkin. Shops make a killing on gear install labor.
post #6 of 22 (permalink) Old 12-29-2003, 06:45 PM
GreenBird's Avatar
and with the gears costing $130 to $200, it becomes a better deal to buy the FRPP pumpkin.
96 Alpine Green V8
post #7 of 22 (permalink) Old 12-29-2003, 06:51 PM
Sheepish
AverageJoe's Avatar
Yes indeed, unless you're dead set on 3.55s or 4.10s
post #8 of 22 (permalink) Old 12-29-2003, 09:05 PM
I would add a J-mod to that mix if you can swing it... it won't help you get off the line, but it'll make your 1-2 and 2-3 shifts snappier. When you upgrade the TC and gears and start to feel that power off the line, you'll want to feel it when you upshift. The J-mod will help you to feel that power all the way through the gears...
Just a suggestion from a guy that always wants more.....
96 GoldBird
N/A:
96 GoldBird is offline
post #9 of 22 (permalink) Old 01-02-2004, 01:54 PM
Send a message via AIM to melecat96
What do u mean by nicer difference and still b good for highway etc.. How exactly do 3.73s effect ure ride
93 Mark VIII (Cobra Mustang drivetrain)
03 Focus ZX3
96 Cougar Xr7 (sold)
melecat96 is offline
post #10 of 22 (permalink) Old 01-02-2004, 02:10 PM
Boom.
Palmguy's Avatar
Generally speaking, the lower number the gear is, the less performance oriented it is. By the same token your engine will have a lower operating speed on the highway with a numerically lower gear.
Your engine will turn less RPMs with 3.55s than 3.73s than 4.10s. 4.10s are more performance oriented than 3.73s and than 3.55s.
The numerically higher the gear, the lower your top speed and the sooner you reach driveline critical speed.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #11 of 22 (permalink) Old 01-02-2004, 02:24 PM
Sweet T
SanDiegoLXBird's Avatar
Especially with JustinH still selling the FRPP centersections for 585 shipped to your door!
1994 SC 5-Speed
SanDiegoLXBird is offline
post #12 of 22 (permalink) Old 01-02-2004, 02:38 PM
The kind of performance they are talking about is not better gas mileage and less engine noise and lower highway engine speeds.
3.73 gears "out-perform" 3.55's in terms of better launch and acceleration from dead stop to top end. Highway gas mileage decreases as the numbers get higher with 3.08 giving the highest mileage and 4.30 the worst. While the difference in gas mileage is significant between the 3.08 and the 3.73.. it is not so significant between the 3.55 and the 3.73, but the difference is performance is.
The 3.73 pumpkin they are recommending as being a more economical way to change gears also has an aluminum housing for less weight and heat retention, and it will actuall cost less to do the pumpkin swap than to buy the gears and pay the labor for the swap, 'cause putting diffential gears in is not something you want to do your self, unless you know what you are doing, but the pumpkin swap is a breeze...
Choices like this always depend on an individual's goals. How "unsluggish do you want it to be, compared to what down sides there may be." 3.55 is a good middle of the road choice, but will cost more to do... 3.73 is a more 'radical' change (but not real radical) cheaper to do (generally speaking), higher performing (as described above), but you will decrease your highway gas mileage, have a bit more engine noise when you drive and your engine will be running at higher rpm to attain the same speeds... also with the 3.73, you're top speed will be lower, but don't worry about that, you'll never see top speed anyway... without a chip, you won't see over 105mph, and anything over that is dangerous without some other upgrades....
96 GoldBird
N/A:
post #13 of 22 (permalink) Old 01-02-2004, 03:33 PM
What years came with 3.55s stock? According to the gear list, I have X - 3.55's with trac-lok (but the trac-lok is burnt out).
94' LX 3.8 here.
Vegeta99 is offline
post #14 of 22 (permalink) Old 01-02-2004, 03:46 PM
To give you an idea, driveline critical speed with 3:73's and stock tire diameter turns out just over 80 mph. Without a chip you won't be able to go over that. You really shouldn't go over that without a lightweight driveshaft anyway. The big dif is that you will be able to get to top end in about 1/4 mile after the change.
BMan
BMan is offline
post #15 of 22 (permalink) Old 01-02-2004, 04:49 PM
Boom.
Palmguy's Avatar
94' LX 3.8 here.
A 3.55 locker is a K code, not X. If you have X I would guess that it is a 3.27 TL. No MN12 came with stock 3.55s.
TCCoA Gun Club
Palmguy is offline
post #16 of 22 (permalink) Old 01-02-2004, 04:55 PM
Palmguy is correct. 3.27 was the highest gear installed buy the factory in a MN-12.
Cam94 is offline
post #17 of 22 (permalink) Old 01-02-2004, 05:36 PM
Sheepish
AverageJoe's Avatar
And the 3.27 codes for MN12s are E and XE. Mine's an E, I don't know why there's two codes for the same setup but there seems to be. Oh well...
post #18 of 22 (permalink) Old 01-02-2004, 10:38 PM
94t-birdlx's Avatar
Send a message via AIM to 94t-birdlx Send a message via MSN to 94t-birdlx
Where do you find the code?
94t-birdlx is offline
post #19 of 22 (permalink) Old 01-02-2004, 11:51 PM
GreenBird's Avatar
Not true. an mn12 will reach a higher top speed with 3.73s than 3.27s.
96 Alpine Green V8
post #20 of 22 (permalink) Old 01-03-2004, 12:30 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea mine is XE, i always wondered why they used 2 different codes.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #21 of 22 (permalink) Old 01-03-2004, 01:00 AM
Sheepish
AverageJoe's Avatar
Thats simply due to the torque multiplication factor of the steeper gears. The car has a higher theoretical top speed with the 3.27s than with the 3.73s if you remove all drag and go on pure numbers.
post #22 of 22 (permalink) Old 01-03-2004, 11:48 PM
thanx guyz that helps alot... i think ill b swaping in some 3.73s cuz i need more accel... i dont care bout a top speed
03 Focus ZX3
