Net rear wheel hp to old gross hp figures pre 1972 - TCCoA Forums
post #1 of 6 (permalink) Old 01-17-2004, 08:54 PM Thread Starter
On Probation
blown96bird's Avatar
I found a great web site to figure out gross hp form net rear wheel hp. Let see if you were making 265 gross hp in 1971 and converted it to net hp you would see around 175 rear wheel hp. If you want to figure out your car gross hp in 1971 you would multiply the net rear wheel hp by a factor of 1.5142857. Lets say your car puts out 100 rwhp in gross hp that would be 151.4 hp by the gross rating. Lets take it up a notch I made 328 rwhp and 364 rwtq If converted to gross it would be 496.7 hp and 545 ftlb of torque. That is much more than many of the big block motors that ford and gm put out. I had a 71 buick electra that put out 345 hp and 460 ftlb of torque. If converted into net rwhp it would be 227 hp and 300 ftlb of torque.
blown96bird is offline
post #2 of 6 (permalink) Old 01-17-2004, 09:27 PM
I would change the 1.51 to something like a 1.25-1.35. Transmissions have advanced since the old days and a 51% decrease from engine to wheels is not likely.
Pooperscooper is offline
post #3 of 6 (permalink) Old 01-17-2004, 11:54 PM
5w30 Guzzler
chilipepprflea's Avatar
Send a message via AIM to chilipepprflea
im assuming that the point of his post was to talk about how they were rated back then vs how they're rated now.
chilipepprflea is offline
post #4 of 6 (permalink) Old 01-18-2004, 07:16 AM
Why would it have changed? I mean isn't a horse power still a horse power?
post #5 of 6 (permalink) Old 01-18-2004, 01:45 PM Thread Starter
On Probation
the way the factory used to do it was with out a air cleaner, no accesory drive belts, water pump usualy with no exhaust manifolds or exhaust and the hp was measured at the crank. The way they do it now is with all acessories in place exhaust manifolds, full factory intake system and full exhaust system. Net wheel hp is measured from the rear wheels and most cars see a 15%-18% loss through the drivetrain.
post #6 of 6 (permalink) Old 01-18-2004, 02:27 PM
AED Specialist
A-Train's Avatar
Smile
Basically, they went from "gross" horsepower at the flywheel to SAE rating at the flywheel. Yes, they now use a complete accessory system and emission controls during the test. Don't forget the correction factor has a lot to do with the overall rating.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
