can a 90mm LMAF be use on an bolt-on modded 97 4.6? - TCCoA Forums
post #1 of 3 (permalink) Old 01-24-2004, 04:12 AM Thread Starter
Moderator & Teksid Whore
guitar maestro's Avatar
reason i ask is because the 90mm LMAF is 34% cheaper than the 85mm GT MAF........am i incorrect in assuming that as long as it is accounted for in the chip/EEC, there would be no problems with driveability?.......or will slightly modded 4.6 use so little of the LMAFs range that it is not worth it?
guitar maestro is offline
post #2 of 3 (permalink) Old 01-24-2004, 09:24 AM
JustinH's Avatar
there isn't much power in a maf upgrade on a near stock car.
But, if you are getting tuned its a "mine as well" situation, because you need to get the maf transfer function tuned anyway, so why not upgrade.
The 90mm maf will work fine for your car. Snoop around the lightning boards, alot of guys are upgrading their 80mm mafs to 90mm, and the 80mm's are going for dirt cheap.
I got mine with an airbox for 40 bucks shipped back in the day on my 95.
JH
JustinH is offline
post #3 of 3 (permalink) Old 01-24-2004, 06:37 PM
Refrigerator Raider Hater
GreenBird's Avatar
the 02+ GT MAF is not 85mm. It is 80mm. Yeah, I know it measures 85mm, but the taper brings it down to 80mm. I got one with airbox, and air tube for $120 shipped.
The LMAF has a much larger range, so it will be less accurate, but not worth more than $20 to go with the 02GT...
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
