FRPP 9mm wires spacers - TCCoA Forums
post #1 of 11 (permalink) Old 01-26-2004, 12:43 AM Thread Starter
i just installed a pair of FRPP 9mm wires, where can I find wire looms or wire spacers to go with these?
thanks
nako103 is offline
post #2 of 11 (permalink) Old 01-26-2004, 01:09 AM
Cougar Pilot
BlackCat94's Avatar
www.summitracing.com
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #3 of 11 (permalink) Old 01-26-2004, 01:57 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
auto parts stores have spacers cheap, provided you arent looking to dress up your engine bay. i think i saw looms at walmart.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 11 (permalink) Old 01-26-2004, 06:26 AM
Rolling-Thunder's Avatar
I have a bunch of blue 9mm looms, some used, some new.
There are different sizes, such as 2-wire, 3-wire, 4-wire, etc.
You can have them if you want, for free
PM me with a shipping address.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #5 of 11 (permalink) Old 01-26-2004, 12:45 PM
JustinH's Avatar
Moroso sells spacers in different colors, you can get them at pretty much any parts store or speed shop, they are pretty cheap.
The frpp wires suck for some reason, I ended up removing a 6 month old set and replacing with OE motorcraft wires after getting a MIL for misfire, which i tracked down to being a faulty wire.
They are overpriced also for some reason.
JustinH is offline
post #6 of 11 (permalink) Old 01-26-2004, 03:49 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
I got Moroso spacers for a v8 and I just didn't use one of the spacers. I did use one of the 4 slot spacers to hold the ignition wire too. I got them for I think 10 dollars at a local parts store.
I also got some blue looming from the local ricer shop.
-Thomas
Thomas is offline
post #7 of 11 (permalink) Old 01-27-2004, 06:57 PM
MaleWhore
smokymance's Avatar
i remembered when i got the livewires, they wanted like $50+ for the wire looms....F THAT...
smokymance is offline
post #8 of 11 (permalink) Old 01-27-2004, 07:00 PM
MaleWhore
smokymance's Avatar
ohh...this might be out of topic...but would running your wires without wire spacers( for now they are lightly zip tied) make the car run rough or missfire?
post #9 of 11 (permalink) Old 01-27-2004, 07:50 PM
Uber Luber
Thomas's Avatar
Probably not since they are FRPP but the insulation will wear away where the wires rub together. I learned that when my Motorcrafts did that because they were touching in one spot. So I deffinetely used spacers and made sure they didn't touch anything anywhere unless it has wire looming around it.
-Thomas
Thomas is offline
post #10 of 11 (permalink) Old 01-28-2004, 12:44 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
-Thomas
He doesn't have the FRPP wires, he's got LiveWires.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #11 of 11 (permalink) Old 01-28-2004, 01:51 PM
Uber Luber
Thomas's Avatar
Okay, well the same still applies they are still aftermarket higher quality wires.
-Thomas
Thomas is offline
