Hard left turns, Fuel pressure drops due to sloshing - TCCoA Forums
post #1 of 13 (permalink) Old 01-28-2004, 07:11 PM Thread Starter
Anyone have the same issue.
hard left turns and the pump sucks air.
This only happens when I get down to about 1/4 tank.
rm
RichardM is offline
post #2 of 13 (permalink) Old 01-29-2004, 10:22 AM
Drnaline's Avatar
Heah Rich, Sounds like your pump bucket moved or fell over. Hasn't happened in my Bird but it does happen. It's usually a pastic one, sits on the bottom of the tank with some kind of retainer. Probably came dislodged.
Democracy is 2 wolves and a lamb voting on dinner. Liberty is a well armed lamb contesting the vote.
Drnaline is offline
post #3 of 13 (permalink) Old 01-29-2004, 11:49 AM Thread Starter
Any idea if it is repairable or is it hosed?
Has done it since I got the car, planning on doing a bunch of things soon so I thought I'd see if there was a fix.
thanks
rm
RichardM is offline
post #4 of 13 (permalink) Old 01-29-2004, 07:53 PM
Drnaline's Avatar
You have to drop the tank. That's the worst part. Pull the sending, if you can't see it reach in and feel for it. Then set it back in it's spot.
Drnaline is offline
post #5 of 13 (permalink) Old 01-30-2004, 09:20 AM Thread Starter
Well the tank is not all that bad. Done it a few times now.
I guess the trick is to get all the fuel out so you can work on whatever is stuck, or messed up.
thx
RichardM is offline
post #6 of 13 (permalink) Old 01-30-2004, 11:48 AM
I would say that is perfectly normal if you only have 1/4 tank. I have experienced the same thing. I just replaced my fuel pump last spring and I know my baffles are in place. You should have at least 1/2 tank of gas when driving aggressively to prevent fuel starvation to the pump. It's also better for the pump to have it completely submerged in fuel for cooling. I've heard of fuel pumps being damaged by running with almost no fuel in the tank. This might only be in certain cars, or an old wives tale. I have run near empty many times and never had a pump die. I do try to have close to 1/2 tank before doing a quarter mile run to prevent fuel from sloshing away from the pump.
Turbo351 is offline
post #7 of 13 (permalink) Old 01-30-2004, 04:26 PM
Refrigerator Raider Hater
GreenBird's Avatar
the pump uses the gas to cool itself, so don't run it low.
it's NOT normal, and the perfect time for a fuel cell if your going that way anyway.
otherwise, I'd look into a tank from a junk...I mean, auto recycler.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #8 of 13 (permalink) Old 01-30-2004, 04:58 PM Thread Starter
to be honest I had my old Tbird, the green car for 6 years and never experienced that issue, so I bet it is the "bucket" deal. I need to measure the pump setup too. It was changed before I got it and if it is bent I realize it could be contributing.
It really takes a hard turn, like a 40-50 mph hard left to make it go. I can see it happen right away, digital fuel pressure in pod
rm
RichardM is offline
post #9 of 13 (permalink) Old 01-31-2004, 01:06 PM
Astrophysicist / PostWhore
66dvlbrd68's Avatar
I got a gas tank from El Mexicano auto salvage like 5 minutes from my house for $65 dollars. Just throwing in my $.02
What are you planning RM?
Mike | RSW | THP | MF | SRTConnection |
1996 Ford Thunderbird LX V8 + 1992 Ford Mustang hatchback + 1989 Ford Mustang notchback = no where else to park at my house!
66dvlbrd68 is offline
post #10 of 13 (permalink) Old 01-31-2004, 01:21 PM
Hmm... what year is your old bird and your new one. The 92 and newer have a smaller fuel tank with different design. The older larger tank will have more fuel at 1/4 tank than the new style. The new style also has a hump in the centre for the exhaust, which might cause the fuel to move differently when the tank is low.
Turbo351 is offline
post #11 of 13 (permalink) Old 01-31-2004, 02:12 PM Thread Starter
It was a '95.
RichardM is offline
post #12 of 13 (permalink) Old 01-31-2004, 04:05 PM
Well, let us know what you find when you drop the tank.
Turbo351 is offline
post #13 of 13 (permalink) Old 01-31-2004, 05:08 PM
fast Ed's Avatar
I've yet to experience any starvation at that fuel level in my 95, even when doing open-track stuff on Hoosier race radials.
cheers,
Ed Nicholson
SCCoO
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
