gas question - TCCoA Forums
post #1 of 4 (permalink) Old 02-01-2004, 10:45 PM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
gas question
do gas stations use some type of injector cleaner in their gas? i know chevron has that techron stuff, but how effective is it? would i be better off just adding lucas or some other FI cleaner?
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 4 (permalink) Old 02-01-2004, 11:45 PM
anomnity's Avatar
amaco does.
Solid Black 1987 T-bird 5.0
anomnity is offline
post #3 of 4 (permalink) Old 02-02-2004, 11:26 PM
Refrigerator Raider Hater
GreenBird's Avatar
Injector cleaner is crap. Either it's something else (like the fuel filter) or they need to be PROFESSIONALLY cleaned.
If you've tried everything else, search the web for a place for a place that cleans, tests and matches sets of injectors. Your injectors might be rated at 19lbs, but they are rarely exact, and some might be over and others under. With a matched set, it still might not be accurate (19lbs) but they will be precise. You would gain power and mileage.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 4 (permalink) Old 02-04-2004, 08:59 PM
anomnity's Avatar
I do know of one cleaner that can probably get rid of anything that is dirty in a motor. I've seen this stuff eat away carbon build up. Its called "GM Top Engine Cleaner". I know this is a GM product but it can eat anything away. All you have to doo is Put this stuff into your motor and let it sit for about 24hrs. After that period start the car up and notice all the black smoke, All this is just the crud in your engine. It will clear up after a few minutes.
anomnity is offline
