^$&#* Maf!!! - TCCoA Forums
post #1 of 7 (permalink) Old 02-02-2004, 01:22 PM Thread Starter
^$&#* Maf!!!
uGH!!! The god damn threadlock Ford uses on those damn screws must be the strongest stuff available! I managed to get ONE screw out, and the other is stripped so bad I can't even attempt to get it more than halfway out. Great. I can't get a hacksaw blade behind it either.
Vegeta99 is offline
post #2 of 7 (permalink) Old 02-02-2004, 09:43 PM
I think sears sells a kit that attaches to a drill so you can get out striped screws. I hope thats what you were getting at. Im sure there are other ways but thats the only thing that comes to mind.
sonicman1634 is offline
post #3 of 7 (permalink) Old 02-02-2004, 11:38 PM
Refrigerator Raider Hater
GreenBird's Avatar
take a drill, and tighten the chuck right over the head.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 7 (permalink) Old 02-02-2004, 11:39 PM Thread Starter
I tried that before, and the drill's too big to get around the screw.
Vegeta99 is offline
post #5 of 7 (permalink) Old 02-04-2004, 12:25 AM
If it's halfway out, the battle's more than half won! You could try using a cutoff wheel to (carefully, very carefully ... don't lose a finger) cut a slot into the head. Then you can turn it with a flathead screwdriver. Or you could just use visegrips, etc. and beat on it until something happens. I would try to get the whole thing out intact rather than cut it off, because it will only be harder to extract with no head.
Steve
S_Mazza is offline
post #6 of 7 (permalink) Old 02-05-2004, 01:39 PM
PCD
Confirmed V6 Nut
Veg,
I've got a spare 70mm MAF housing I could send you. You could get regular screws to put a new MAF sensor in it. I'll let some MAF guru tell you if you need a different MAF than your stock one to use my housing.
PCD is offline
post #7 of 7 (permalink) Old 02-05-2004, 04:20 PM
Most stores call them "easy outs" or "screw extractors" i bought a cheap set that came with 5 sizes of extractors and matching drill bits. Drill a hole down from the top, put the extractor down in the hole and drill away in reverse. its like a reverse cut drill bit that bites down in the hole you drilled and turns the screw. Good ole tamper proof stuff.........
JohnNaas is offline
