hi, This is Tony's Mom :P - TCCoA Forums
post #1 of 11 (permalink) Old 02-05-2004, 04:38 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
I was just wondering if anyone could tell me why a car would get warmed up and then stall ? ...... okay now smarty pants ...LOL LETS SEE WHO KNOWS WHAT THEY ARE TALKING ABOUT ...HEHEHEH ......
Tony is at work ......so tell him to be nice to me for getting on this site and asking .... LOL ......(wink)
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #2 of 11 (permalink) Old 02-05-2004, 05:20 PM
Thunderterd's Avatar
Hi Tony's Mom...
If you could provide more informatino
Like
Type of car , Engine, all the paticulars.
AAAAA: American Association Against Acronym Abuse
Click here if you are an idiot
Llama!!!
Thunderterd is offline
post #3 of 11 (permalink) Old 02-05-2004, 05:35 PM
Temperature sensor possibly.
Temp sensor is still reading cold after warm up and telling the EEC that the engine is cold and needs more gas than air, so it floods itself. Too rich.
Need more info though about what it exactly does. Do you give it some pedal and it stumbles and dies?
soop is offline
post #4 of 11 (permalink) Old 02-05-2004, 06:05 PM
JR Tigerstar's Avatar
JR Tigerstar is offline
post #5 of 11 (permalink) Old 02-05-2004, 07:53 PM
4 Cam Bird's Avatar
If its carbed, I am going to say the choke is stuck closed. I have also heard of this symptom with clogged cats.
2011 CTS-V Wagon
4 Cam Bird is offline
post #6 of 11 (permalink) Old 02-05-2004, 08:15 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Heys guys, this is me! ...LOL Just got home from work. Got on here to check the forums and found this... surprised me!
Anyways I do beleive she is talking about my uncles 86 Cougar 5.0 EFI. I have been busy lately and haven't had a chance to check it out for him. So my mom, as you can see tried to get some info on her own. So anyways, whenever the car gets up to operating temp it stalls. That is actually all I know because I am having two women try and tell me whats wrong without me even seeing the car or having anymore info and expect me to know what is wrong with it.
So if you guys know of any common problems with this situation let me know!
Note: they just told me that they rplaced the MAP sensor which someone told them was the problem, but wasn't.
I always tell her how much this site has helped me and stuff, so that's why she tried here.
Thanks!
Tony is offline
post #7 of 11 (permalink) Old 02-05-2004, 11:41 PM
Refrigerator Raider Hater
GreenBird's Avatar
I'd say while your mom might not know about cars, she's pretty smart to get on here...
what about the o2 sensors? They are not used in warm-up but once heated, the EEC uses them, and they could stall the engine by making it rich or lean.
Best bet is to read the codes if there are any.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #8 of 11 (permalink) Old 02-06-2004, 03:28 AM
5.0 Chero's Avatar
First of does it start right back up? If not and it has to sit for a while. Check out the TFI unit. When it stalls pull coil wire and check for spark if none replace TFI.
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #9 of 11 (permalink) Old 02-21-2004, 05:50 PM
Tony, did your Ma get this taken care of?
soop is offline
post #10 of 11 (permalink) Old 02-22-2004, 12:30 AM
tony's moms cool....she knows how to use the internet...
when i told my mom wat the address bar was, she put in out home adress....
baseer is offline
post #11 of 11 (permalink) Old 02-22-2004, 03:26 PM
jk69cat's Avatar
could be the sator in the distributor. seen that a few times.
mn12 less!
jk69cat is offline
