Stock shift points vs. chipped... - TCCoA Forums
post #1 of 21 (permalink) Old 02-08-2004, 10:33 AM Thread Starter
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Can someone tell me what the stock shift points (I think like 4900 for the 1-2 and like 5100 for the 2-3, at least thats how my buddies 94 shifts) are and what they are when you get a apten chip? I beleive my shift points with the chip are 5600rpms, but wanna make sure. And my rev limiters are at 6000, is that right? Seems kinda dangerous so thats why I am asking, but my tach may just be off a little. And what rpm is the "balooning" supposed to occur?
Thanks!
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #2 of 21 (permalink) Old 02-11-2004, 06:33 PM
J.Miller's Avatar
I assume you mean the WOT shift points. Here are the stock numbers for a 97 EEC:
Trans WOT shift 1-2: 4350 RPM
Trans WOT shift 2-3: 4850 RPM
Trans WOT shift 3-4: 4800 RPM
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
post #3 of 21 (permalink) Old 02-11-2004, 10:00 PM
281_TBird's Avatar
4350 1-2???? mine shifts at like 4800 on the 1-2 like teh 2-3 and 3-4.
1997 Ford Thunderbird, Built NA 2V/ T-45
1997 Ford Explorer AWD 5.0L
2003 Lincoln LS V8 Bolt Ons
2009 Yamaha VMax
2011 F-150 Lariat Limited 6.2L 4WD
2015 Ford Mustang GT Premium, Performance Pack, Recaros
281_TBird is offline
post #4 of 21 (permalink) Old 02-12-2004, 01:07 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
It takes time for the clutches to fill. The EEC has to command the gear shift long enough ahead to allow the clutches to fill and actually start bringing the rpms down and engaging the next gear. In a stock car's case that shifts around 4900, it take that 500-600 rpms to fill the clutches.
Check out the tech articles, Ford OD Transmissions 101
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #5 of 21 (permalink) Old 02-12-2004, 07:01 AM
Boom.
Palmguy's Avatar
Thanks!
Stock converter I believe 5400.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #6 of 21 (permalink) Old 02-12-2004, 09:59 AM
281_TBird's Avatar
I guess I never thought of that. Thanks for the info, I learn something new everyday here!
2009 Yamaha VMax
post #7 of 21 (permalink) Old 02-12-2004, 03:13 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Are there any issues with a 98 mark8 TC ballooning?
-Thomas
Thomas is offline
post #8 of 21 (permalink) Old 02-12-2004, 03:24 PM
Silver95Bird's Avatar
Yes, but I think it's up around 6500 or so if I recall right... but your stock rods wont go that high so it's not a worry
Silver95Bird is offline
post #9 of 21 (permalink) Old 02-12-2004, 08:15 PM
Sheepish
AverageJoe's Avatar
Agreed, especially considering the stock engine won't any real power that high anyways.
post #10 of 21 (permalink) Old 02-14-2004, 02:29 AM
MaleWhore
smokymance's Avatar
as i have heard, they put the top speed limiter for some reasons, and one was the TC...now if u upgrade to a mark viii, is the speed raised?(assuming with appropriate DS)if so, how much? what about the marauder TC?
smokymance is offline
post #11 of 21 (permalink) Old 02-14-2004, 02:52 AM
Sheepish
AverageJoe's Avatar
The TC's safety concern isn't in regards to vehicle speed, just engine rpm. The TC begins to balloon around 5400rpms, and if allowed to do so, could stretch to the point that the bearings can fall out of their races and trash the converter, taking the transmission with it. The Mark VIII and Marauder units don't balloon until the 6500rpm range.
The driveshaft is one concern that the speed limiter is set so low, but its not nearly the deathtrap that people think it is.
The biggest reason that the speed limiter is set so low is because the factory tires are only speed rated to 112mph.
post #12 of 21 (permalink) Old 02-14-2004, 08:10 AM
J.Miller's Avatar
Here I go again up on top of my soap box!
That 5400 RPMS is assuming a relatively new torque converter. As the torque converter ages, stresses build up in the material that could weaken the metal and cause ballooning a little earlier. This is what I call aging…
The limited service life is part of every mechanical design. This is the reason you see 20 year old air planes going into retirement or restoration. If they did not they would crash. Trust me when I say the design service life of automobiles is not as long as airplanes. They want you to buy new car!
In addition, as your transmission gets older the pump just does not pump like it used to. It takes longer to ramp up the torque converter and this can be a problem since you get near the ballooning point.
I like to keep my transmission as long as I can so that I can throw my money at other things. Even though I have a well made Pro Torque torque converter and a Art-Carr transmission I make sure that my transmission shifts below 4800 RPM's under WOT conditions.
J.Miller
J.Miller is offline
post #13 of 21 (permalink) Old 02-14-2004, 02:35 PM
281_TBird's Avatar
So what are the shift points with an apten, J-chip, ect.....
2009 Yamaha VMax
post #14 of 21 (permalink) Old 02-14-2004, 02:52 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
with an apten chip my car shifts at about 5500 rpms for the 1-2 and about 5600-5700 for the 2-3.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #15 of 21 (permalink) Old 02-14-2004, 06:37 PM
281_TBird's Avatar
If I get an apten chip will it baloon my TC? I thought they worked fine with a stock driveline
2009 Yamaha VMax
post #16 of 21 (permalink) Old 02-14-2004, 06:48 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Frank
Yea that's about were mine shifts or at least that is how high the rpms get while shifting. I know there is a slight delay so I would guess the tranny is told to shift at about 5400.
This is why I asked this question. I was pretty sure the balooning was 5400 and I know my shifts are above that. But know one with chips seemed top have any issues. Why is that? Has anyone even blew up there stock TC before?
One time I was stuck in/on some ice behind my house. I had a few friends pushing me while I had it in reverse. I was giving it some gas and I was turned around looking behind me (being thart I am trying to go in reverse) and when I turn around I see that I am at 6000 RPMS. So thats why I actually made this thread. With a chip is there a rev limiter?
Tony is offline
post #17 of 21 (permalink) Old 02-14-2004, 06:52 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Or is that because you have a 5.4 and there is no need to go that high??
Tony is offline
post #18 of 21 (permalink) Old 02-14-2004, 06:53 PM
Uber Luber
Thomas's Avatar
nope, but if you ask I'm sure they'd let you keep it. I'd sure want to keep it, or at least set it a bit higher than stock.
Yesterday I was leaving a snowy parking lot in a not-so-great mood and stomped on it, look down and the tach says 5500. Now that's a lot for my 3.8 that shifts at 4300. Kinda scared me for a sec.
-Thomas
Thomas is offline
post #19 of 21 (permalink) Old 02-14-2004, 07:26 PM
Carlover007's Avatar
My tach was broken when i got it, so i don't have to worry about it.
Carlover007 is offline
post #20 of 21 (permalink) Old 02-14-2004, 08:51 PM
Refrigerator Raider Hater
GreenBird's Avatar
completely removing the rev limiter is stupid. there is no reason to, your engine stops making power at a certain point, and it leaves it open to a grenade mishap.
None of the SCT family completely removes the limiter. If I was a tuner I would refuse to do it
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #21 of 21 (permalink) Old 02-14-2004, 09:28 PM
Slacks 12 months a year
LX-Tasy's Avatar
My 96 is totally stock but for some reason it shifts at about 5400.
Chris
"My Other Ride Is Your Girl"
LX-Tasy is offline
post #22 of 21 (permalink) Old 02-15-2004, 07:55 AM
J.Miller's Avatar
Nice try! My motor is makes power above 5,000 RPM's. I think the motor can make 6,000 if I wanted to.
Here is a Dyno:
J.Miller
J.Miller is offline
post #23 of 21 (permalink) Old 02-15-2004, 12:50 PM
Uber Luber
Thomas's Avatar
Wow talk about low end power. Also looks like it dogs out at 5k to me. Maybe I'm reading it wrong. All the dyno's I've seen are ascending, you're descends. Maybe it's because I look at v6 dyno sheets
-Thomas
EDIT: Yes, yes I did read it wrong. That's a pretty nice flat power curve.
Thomas is offline
post #24 of 21 (permalink) Old 02-15-2004, 02:51 PM
J.Miller's Avatar
That is because I have both HP and torque there. Torque is on the top and goes down and HP is on the bottom going up. It peaks around 5400 RPM but I do not let it go that high even though I have a forged 8 bolt crank, high flow oil pump, Stall TQ, AL driveshaft, bullet proof tranny, a Tranny cooler and a few tricks.
J.Miller
J.Miller is offline
post #25 of 21 (permalink) Old 02-15-2004, 08:23 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Yea, I was just messin' with ya... that is some insane low-end!!
So the only reason you don't shift that high with all the tricks and goodies is for the safety? I thought thats what all the tricks and goodies are for, to make it run at its fullest potential?! Or is there some other reason why? All those goodies you named are made to take the abuse!
Tony is offline
post #26 of 21 (permalink) Old 02-15-2004, 09:40 PM
J.Miller's Avatar
No one abuses a car more than I do on a daily basis. I have been doing it for years and have over 100,000 miles on the transmission to show for it.
You do not run a car to its all out maximum every day and expect it to last. A factor of safety is a must.
J.Miller
J.Miller is offline
