Window Fell Off Track!! uhhhhh....help - TCCoA Forums
post #1 of 3 (permalink) Old 10-11-2002, 11:32 PM Thread Starter
CatBird Creator
Send a message via AIM to ChromeTip
My driver side window fell off its track today. the mechanism goes up and down just fine, but the window is not adhered to it anymore. I pushed to window all the way up and then made the track go up to, so it holds the window up all the time. i can go down, cuz the window will just sit there, but the track will go down. right now my door panel is off and i can see inside perfectly. all i need to know is how to adhere the window back in place? what did ford use to do this? I need it too because since i cant roll down my window, and i have tints, i'm a little paranoid driving around. but anyways, thanks a lot to whomever helps me
Kyle
~Legendary Catbird Creator~
Now owner of 1994 Thunderbird LX...where do i start?
ChromeTip is offline
post #2 of 3 (permalink) Old 10-12-2002, 02:02 AM
Same happened to me. I used a 5min. epoxy system, you mix these two thick fluids together and it dries extremely strong. Just apply it over that little tab that holds the glass and mount the glass. Wait about an hour to let dry, to be on the safe side. Some dripped on the inside of the door and when it dried it was hard as a marble.
Also make sure when you are mounting the glass back in place that it is shifted correctly. It can be off too much to the left or right. I looked closely and I could see a mark exacty where the glass sat in the tab.
bagged90SC is offline
post #3 of 3 (permalink) Old 10-12-2002, 11:45 AM
Drive XR7's Avatar
Send a message via AIM to Drive XR7
Yea use that Epoxy stuff... should work, my friend used some Aquarium sealant on his old car windows to get them stuck to the other mechanism, whatever it is.
Jason
2003 SVT Mustang Cobra #5364
2001 Pontiac Grand Prix GTP
1991 Mercury Cougar XR7 5.0L - SOLD!
Drive XR7 is offline
