Power Steering Help! - TCCoA Forums
post #1 of 3 (permalink) Old 10-17-2002, 09:07 PM Thread Starter
Angry Power Steering Help!
My power steering is leaking I think. The fluid level drops from max to mix in about 10 miles. Has anyone else had problems of this nature? Do you think its a leak. If so how Much approximately?
thunderchickin46 is offline
post #2 of 3 (permalink) Old 10-17-2002, 10:51 PM
Send a message via AIM to tbirdfive0
yup.. check the rubber elbo 90/90 elbo right behind the plastic part of the pump... it corrodes when it gets old and cracks.. if thats it just the metal line right before the rubber part then buy a pice of hoes that size and use a hose clamp on each end to fix it.
dont let it run down... i did... i had to replace my pump... and my rack
Jay
2006 Ford Fusion SEL V6
tbirdfive0 is offline
post #3 of 3 (permalink) Old 10-18-2002, 01:27 PM Thread Starter
Okay
Okay I'm going to check that out , thanks alot! I'll get back with info later.
