Your first time rebuilding your 4.6.. - TCCoA Forums
post #1 of 7 (permalink) Old 10-18-2002, 08:53 PM Thread Starter
Thumbs up Your first time rebuilding your 4.6..
how was it? were you scared? did everything work out? im thinking of buying a engine that needs to be rebuilt for cheap, but im kind of worried that i would rebuild it and put it in and something would go wrong. what did you guys do on your first time to get over your worries?
silvershot is offline
post #2 of 7 (permalink) Old 10-18-2002, 11:37 PM
Well I will tell you this, Im in the middle of my headswap right now. And after about 7-8 hours of work, all i have left to do it get off the drives side head, after then I get to start putting everything back. Nothing has been too hard, Some stuff just takes a lot of time (PS pump sucks, My hand still hurts) I know that the heads really isn't much in a rebuild but it doesn't look to hard. Just make sure you have the right tools
BlackTbird96 is offline
post #3 of 7 (permalink) Old 10-19-2002, 12:15 AM
Overkill Fetish Freak
Who's your daddy?
Dr. FrankenCougie is offline
post #4 of 7 (permalink) Old 10-19-2002, 12:48 AM
Yea you see those 3 little bolts up there all next to each other. Yea they SUCK! I should have got the pictures of all the blood on the ground and my hand when I got it off. You would have thought I was dieing.
post #5 of 7 (permalink) Old 10-19-2002, 10:17 AM Thread Starter
what size wrench did you use to get in there? you must didnt have too much wrench space to move up in there? was the motor mounts a PITA? that is one of my major concerns at this time. how did you get those off? what did you do for the A/C unit? did you open the lines to remove the engine, or was you able to keep them connected? :frog:
post #6 of 7 (permalink) Old 10-19-2002, 09:55 PM
If I remember...
I think that wrench was an 8mm. I went at it through the hole in the PS pump pump pully. like 1/12th of a turn at a time. tedious. I didint touch to motormounts (just did the headswap) but I havn't heard of them being bad. And i'm pretty sure you just diconnect the a/c compressor from the block and hang it on the side.
chadg is offline
post #7 of 7 (permalink) Old 10-20-2002, 03:31 AM
VicRattlehead's Avatar
ac and powersteering were totally left in the car when i pulled the old motor out. no need to "remove" them from the car, they just hang there nicely.
as for the motor mounts thoes are not hard at all. 3 bolts per side, that go to the block, one bolt per side that go to the frame. the frome ones can be had with a 12-13mm?? not sure, socket with an extention. the head of the bolt is accessable after you remove the ps/ac pumps other than that its not hard, it didnt take me but an hour or so to bolt the motor in when we droped it in.
questions? shoot.
CMP Drag Racing
VicRattlehead is offline
