radiator problem - TCCoA Forums
post #1 of 7 (permalink) Old 10-22-2002, 11:18 AM Thread Starter
radiator problem
lately when ive been driving with my a/c on i can smell radiator fluid on the car. i already by passeds the heater core so i dont know what it is. also my car has been running hott ocassionally. i have no clue why it does this but when it does run hot the coolant over flow tank fills with boiling coilant. alright thanks for your help and if you need any more info just ask
thanks Trent
93CougarXR7 is offline
post #2 of 7 (permalink) Old 10-22-2002, 11:40 AM
Take it to the radiator shop and get it flushed.
You may have a clogged radiator.
If it is not dripping from the radiator you are probabaly smelling the fluid that is boiling out of the radiator overflow.
with a little luck your heater core may still be ok. That means you don't have to take the dash off to fix it.
A radiator flush should be pretty cheap and you can't hurt anything in the process.
danman
danman is offline
post #3 of 7 (permalink) Old 10-22-2002, 12:13 PM
Rolling-Thunder's Avatar
When you by-passed the heater core, you must have had to add more coolant after putting everything back together.
Did you bleed out the air when you were adding anti-freeze?
Sorry, not up on the xr7's, which engine do you have?
If it's the 3.8 it has a vent plug on the intake, and this allows air to escape while adding anti-freeze
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #4 of 7 (permalink) Old 10-22-2002, 12:25 PM
CamellionCat's Avatar
Send a message via AIM to CamellionCat
ohhhhh that dosent sound right.
last time my overflow tank overflowed it was b/c of a blown headgasket, also check the oil for coolant to be on the safe side.
Marvin M.
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #5 of 7 (permalink) Old 10-22-2002, 12:54 PM Thread Starter
the xr7s have a 5.0 and what are some sypthoms of a blown head gasket?
post #6 of 7 (permalink) Old 10-22-2002, 12:58 PM
Post the symtoms are............
coolant in the oil and white smoke coming out of the exhaust. Or if its really blown your car can also tremble a lot. Like if you had a messed up motor mount.
Marvin M.
Back in the game!!!
post #7 of 7 (permalink) Old 10-22-2002, 01:26 PM
I had an 86 Cougar LS with the 3.8, and with a head gasket leak;
the car would run fine, and then in a matter of a few seconds, the temperature gauge would peg all the way to the red, accompanied by some knocking or pinging sounds from the engine. The coolant level was down by one-half gallon after each episode.
I gave this car back to the dealer, and I purchased another 86 Cougar LS, but this one had the 5.0 Low and behold, after a couple of years, the car would occassionally get low on coolant. It did not run hot. The dealer kept testing it, and found nothing wrong. Finally, the head gasket let loose between a cylinder and a coolant passage in the block, and I had a white smoke cloud pouring out of the exhaust.
Dealer fixed it, and paid 75% of the repairs.
