Engine temp jumps within first 10 min. - TCCoA Forums
post #1 of 6 (permalink) Old 10-23-2002, 11:53 AM Thread Starter
I have a '93 t-bird v6. Occasionally this happens: The engine temp will jump all the way to the top within the first 10 minutes of driving. Then settle back down to normal for the rest of the drive, never going back up. Also if the heat is on, all it blows is cold air till the temp needle goes back to normal. My question is; is the thermastat going? Any suggestions would be helpful....Thanks
,CHRIS
creid is offline
post #2 of 6 (permalink) Old 10-23-2002, 12:06 PM
Re: Engine temp jumps within first 10 min.
,CHRIS
Change your thermostat NOW and do a coolant flush. You are likely low on coolant and don't mess around with the temperature or t-stat unless you want to replace some headgaskets any time soon.
So....
what are you waiting for? GO! NOW!
soop is offline
post #3 of 6 (permalink) Old 10-23-2002, 12:32 PM
What he said...............
MadDog2020 is offline
post #4 of 6 (permalink) Old 10-23-2002, 01:07 PM
Arrow
You ain't done yet?
doodaa is offline
post #5 of 6 (permalink) Old 10-23-2002, 04:21 PM Thread Starter
Thanks for the info,.....getting it replaced tommorow.
,CHRIS
creid is offline
post #6 of 6 (permalink) Old 10-23-2002, 05:50 PM
,CHRIS
Well, it's about time!
soop is offline
