bosch plugs - TCCoA Forums
post #1 of 14 (permalink) Old 10-25-2002, 05:16 PM Thread Starter
bosch plugs
I've heard other people have had bad experiences with Bosch plugs. Here's mine: About 6 months ago I bought a set of the bosch platinum +4 plugs and ultra premium wires and paid about $150. The car ran fine at first but about 15,000 miles later the engine started to miss every so often under low throttle. The problem slowly started to get worse. My cougar ran like ****, especially when cold. I talked to a guy at Five Star Ford and he said that you can't use Bosch plugs in any Ford vehicle. Although I know he was trying to sell me a set of plugs, is there any truth to this statement? I decided to just swap the plugs with NGK's. The engine hasn't missed since and it idle's noticeably smoother. What's the story on these Bosch plugs?
95zr7 is offline
post #2 of 14 (permalink) Old 10-25-2002, 07:29 PM
BOSCH
I use the standard Bosch plugs and haven't hab a problem yet.
But it's not cold here yet.
Fuel man~~~
Fuel man is offline
post #3 of 14 (permalink) Old 10-25-2002, 11:06 PM
JustinH's Avatar
i save the bosch plugs for my VW.
the birdy gets motorcraft coppers.
Justin
JustinH is offline
post #4 of 14 (permalink) Old 10-26-2002, 02:45 AM
Get rid of Bosch...
Motorcraft Plat Plus in my 4.6
Or as Justin said coppers are good too.
My SC had them crapola plugs in them when I bought it. I changed them to Autoligh 764 I believe the number was asn the slight miss and lack of power problem went away. FWIW, I have read about more folks having trouble with these in Fords for some reason.
Jim Long
Blown94SC is offline
post #5 of 14 (permalink) Old 10-26-2002, 05:02 PM
BlackbirdSport's Avatar
Send a message via AIM to BlackbirdSport
Originally posted by Blown94SC
My SC had them crapola plugs in them when I bought it. I changed them Jim Long
listen to this man!
Anyone who changes their own SC plugs is going to be DANG sure he gets the best, longest lasting plug possible. That is not something you'll want to do again any time soon :
"Keep making it thinner until it breaks, then go one size bigger."
My Cougar XR7
BlackbirdSport is offline
post #6 of 14 (permalink) Old 10-26-2002, 07:03 PM
After that pain in the aaa those plugs will be in there for a long time. In fact till the motor comes out for rebuild. I will change 4.6's all day long before I do an SC again....
post #7 of 14 (permalink) Old 10-29-2002, 09:50 PM
Moderator & Teksid Whore
guitar maestro's Avatar
i used bosch platinums, and +4's on my '93 XR& 3.8 and never had a single problem in the 2-1/2 years i owned it......now my '97 XR7 4.6 has bosch platinums and runs smooth as smooth can be.......i just got the 97 in late July, and put the Bosch in August....time will tell how things go, but i doublt i will have any problems
guitar maestro is offline
post #8 of 14 (permalink) Old 10-30-2002, 01:06 PM
I would
I would stick to Motorcraft plugs.......When it comes to electrical stuff like that....Stick to Motorcraft......My car is a Cali emissions car and calls for Motorcraft Double Platinum
BeirutsFinest
BeirutsFinest is offline
post #9 of 14 (permalink) Old 10-30-2002, 01:27 PM
High Output Poster
91HellCat's Avatar
Send a message via AIM to 91HellCat
I have worked for AutoZone for 2.5 years now and have learned alot about plugs.
The #1 rule is: Stay with OE plugs...you can never go wrong with OE!
Bosch plugs are pretty much only for German cars. Kinda like the Densos are for Japenese cars.
I sell a lot of Bosch plugs at work. The Fords do ok with Bosch from the comments that I get from customers. Ford cars arent as picky as say GM. Dont even think of using Bosch in a newer GM (because of the ignition system).
I run Motorcraft in my Bird, if i try any other plug, it will be NGK iridium or V-power.
NGKs are awesome. I have yet to hear one bad comment on any NGK plug. I had Bosch, Denso and then NGKs on my old Accord. The NGKs are great!
I'm not bashing any manufacturer. Just stating some facts and opinions. And my 2 cents...maybe 3.
1991 Ford Mustang GT
1998 Lincoln Continental
1999 Mercury Mountaineer 5.0
91HellCat is offline
post #10 of 14 (permalink) Old 10-30-2002, 05:27 PM
dang racist plugs!
My Cougar XR7
post #11 of 14 (permalink) Old 10-31-2002, 02:57 PM
ChatWhore
lobird91's Avatar
Send a message via AIM to lobird91
Denso Plugs
I have never used them personally but 5.0 mustang magazine put them in their project GT and they were recommended by Steeda so they may work OK in a 4.6 car. I just changed plugs in my 96 and went with Autolight Plat. which seem to be working quite well.
Remember, if it isn't broken your not trying hard enough.
lobird91 is offline
post #12 of 14 (permalink) Old 10-31-2002, 03:43 PM
i had a 89 3.8 lx, it missed alot and got crappy mileage with the bosch platinum +4. i then went out and got the motorcrafts, ran much better. boy was that a PITA.
i have a 95 4.6 lx now, i am using the single electrode bosch platinums in it and they work just fine.
mabye it is only the +4s.
anothergreenbird2 is offline
post #13 of 14 (permalink) Old 11-01-2002, 04:32 AM
HMMMM
Am I the only one running splitfires? I have always used them in my bird and never had a problem. The guy at the autopart store was real negative about me using them but I am satified.
DIABLO is offline
post #14 of 14 (permalink) Old 11-01-2002, 08:48 AM
Automatic Weapon
Big-Al's Avatar
I ran Split Fires for a while, but after getting cursed at by every mechanic I talked to about Split Fires, I decided I may as well go with Ford plugs. They're cheaper anyway
<----not throwing rocks at girls anymore
Big-Al is offline
