90-96 IRS for Tbird and Coug ????'s - TCCoA Forums
post #1 of 6 (permalink) Old 10-25-2002, 06:29 PM Thread Starter
Question 90-96 IRS for Tbird and Coug ????'s
I am building a Monster v8 Mazda Miata and need some rear suspension parts.
I have been told by others making the V8 swap that the 90 - 96 Tbird.Cougar rear suspension is the way to go.
Do any of you guys know where I can get to a website for some pics and info on the REAR sus and diff for one of these cars ?
markmartinbirdie is offline
post #2 of 6 (permalink) Old 10-25-2002, 07:23 PM
ummm you really think you can fit a tbird IRS into a miata frame?
billabong132 is offline
post #3 of 6 (permalink) Old 10-25-2002, 07:26 PM Thread Starter
Yes
Go to V8miata.com and check it out. They put a 302 and a 5 speed with the IRS . cool package Do you know of any websites with pictures of the IRS ?
post #4 of 6 (permalink) Old 10-25-2002, 08:22 PM
hmm when you do it I wanna see it!!
check on ebay, they had a complete MARK VIII IRS setup on there with some good pictures of the assembly put together. (The same IRS in the tbirds and cougies).
post #5 of 6 (permalink) Old 10-25-2002, 10:58 PM
Tweeeeka's Avatar
You might wanna check out mn12performance.com's technical article on strengthening the IRS subframe. It's got alot of really good pictures and a few good technical drawings of the tbird/cougar/markVII IRS. I would suggest going with a Mark VIII IRS since its got aluminum lower control arms and is slightly lighter. If you get one out of a tbird or cougar make sure it came out of a V8 or SC car so that you get the 8.8" differential. They should have a tag that indicates what size diff is.
Tweeeeka is offline
post #6 of 6 (permalink) Old 10-25-2002, 11:29 PM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Do you mean 89-97? Them were the years of the MN12.
If you go into the Exhaust Gallery , there are a bunch of 'under the car shots'. I will try and find some nice clear pics for you if I can!
That V8 Miata is pretty neat though (lotsa Ford parts ) , had to be a lot of work too!
And definatly read/look through that link that tweeeka gave you!
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
