Anything special I should about ABS before tearing it apart? - TCCoA Forums
post #1 of 6 (permalink) Old 10-25-2002, 08:33 PM Thread Starter
This is really about my mom's 90 ranger but it applies to my bird also.
IT has rear ABS, and I have heard that ABS systems need special tools and use high pressure blah blah. I kinda doubt this since manuals say the same thing about ac work and its a breeze. (No pubn intended) I need to replace a rear caliper, do I just do it like a normal brake caliper? Do I have to go through some special bleeding procedure afterwards? thanks.
billabong132 is offline
post #2 of 6 (permalink) Old 10-26-2002, 01:51 AM
The Band, not the Disease!
AnthraxBird's Avatar
It "Should" be the same.. But if you remove the line, and you have to bleed the system... it is different. Someone have the CD for the tbirds manual?? I only have a Hanes book
AnthraxBird is offline
post #3 of 6 (permalink) Old 10-26-2002, 01:57 AM Thread Starter
well like I said, this is really for my mom's ranger than my tbird. I have a ford shop manual for the birdie and in the ABS section under bleeding it says refer to section 06-xx-xx witch is the section for standard bleeding.
post #4 of 6 (permalink) Old 10-26-2002, 03:11 AM
Are you just bleeding the brakes? If that's the case, then you just have to remember to bleed them in this sequence: right rear, left rear, right front, left front.
soop is offline
post #5 of 6 (permalink) Old 10-26-2002, 12:58 PM Thread Starter
no, I'm replacing one of the rear calipers, I thought that bleeding sequence was for 4 wheel ABS? This only has rear ABS.
post #6 of 6 (permalink) Old 10-26-2002, 01:11 PM
So you will be detaching and bleeding the rear line then. The sequence is there for the rear lines anyway.
soop is offline
