problems when car is cold!!! - TCCoA Forums
post #1 of 4 (permalink) Old 11-03-2002, 06:41 PM Thread Starter
Ok guys here is my problem. When I first start my car in the morning or after it has sat for hours it will idle at about 1000 rpm. My regular idle is at about 750 or so. Now when it is cold and I hit the throttle the engine seems to choke out for a second and the rpms drop, sometimes even to the point of the car stalling. This only happens when the car is cold and after a few minutes of driving everything returns to normal and the car runs fine. I have no idea what this problem is. If it were my TPS then it should have the problem all the time, correct? And if it were a vacuum line it should not only affect the car when it is cold!!! has anyone had similar problems or does anyone know where i can look for a fix for this..
thanks, your help is greatly appreciated
CanadianCat
CanadianCat is offline
post #2 of 4 (permalink) Old 11-03-2002, 06:50 PM
Alex's Avatar
Send a message via AIM to Alex
Clean, clean, clean yo MAF. (in a chant-like rhythm)
1991 Mercury Cougar LS (Dead)
1989 Ford Probe LX (Dead)
1989 Ford Taurus SHO (Sold)
1994 Ford Taurus SHO (Dead)
1994 Ford Taurus SHO (Weekend Cruiser)
1999 Honda Accord EX (Daily Driver)
Alex is offline
post #3 of 4 (permalink) Old 11-03-2002, 09:00 PM
Might be the coolant temp reading too warm and running you a bit lean at startup. Don't know if the intake air temp has as great an effect on mixture. Throwing any codes?
bill_s is offline
post #4 of 4 (permalink) Old 11-03-2002, 11:41 PM
Old wisdom in cold climates allways was to Idle the car for a few minutes , letting it warm up to eliminate stalling or hesitation in traffic, plus not putting a strain on cold parts that are more fragile... all that being said , Your IAC valve should prevent stalling and hesitation, but it wont work up to snuff if its greasy/dirty/clogged ,and it will be stiff too, until the car is warm if greasy.. Check it ,clean it, or replace it....LOL
Leland Jacobson is offline
