can I replace caliper slide pins? - TCCoA Forums
post #1 of 2 (permalink) Old 11-03-2002, 11:04 PM Thread Starter
My right caliper sticks, do the make a repair or help kit for our birds that have new caliper pins??
if they are removable I just need to take the torx bolts out right?
What size torx bit do I need?
thanks, chad.
billabong132 is offline
post #2 of 2 (permalink) Old 11-04-2002, 12:00 AM
caliper slide pins
I can't remember what size torx you need but you can take them out. I usually buff them clean & smooth, then put silglide (brake lube) on them and the rubber sleeve and reinstall them. I hope that is the only problem with them because sometimes the caliper itself sticks. good luck
vancouverBC is offline
