Tire 'feathering' problem ... - TCCoA Forums
post #1 of 9 (permalink) Old 11-04-2002, 11:59 AM Thread Starter
Unhappy Tire 'feathering' problem ...
I've had my car alligned just fine - well within specs relatively recently. and I'm still having problems with my tires feathering on my front tires.
This has happened with every set of tires I've ever had on the car, recently with my Michelin X-Ones, and now with my Blizzaks.
I'm a bit concerned, especially wth the winter tires, as their tread will just die with it continues.
I DO NOT corner hard at all - and drive really 'softly.' So I don't know what can be the problem.
Any suggestions?
Also - I'll also post this in the 'wanted' section - but I'm looking for Eibach lowering springs, and compatable shocks for my 92 Cougar.
drl176 is offline
post #2 of 9 (permalink) Old 11-04-2002, 12:07 PM
Make sure the tire pressure you are running is good for the tires.
Low or high pressure can eat tires.
danman
danman is offline
post #3 of 9 (permalink) Old 11-04-2002, 03:20 PM Thread Starter
I check my tire pressure religiously (once every 2 weeks, at least), as it happens - ever since I noticed the problem - about two years ago. I kinda just ignored it, as it wasn't a huge problem for me on the Michelin X-One's - but I'm very concerned with the much softer Blizzak tire compound.
drl176 is offline
post #4 of 9 (permalink) Old 11-04-2002, 04:20 PM
knife edge
When standing next to the tire, place your hand on the tire-tread and rub your hand across the tread, does it feel as though the tread has a knife edge to it?
Pulling toward you if you feel an edge to much toe-in, pushing away from you and you feel the edge to much toe-out.
I've also but rarely run into to much positive caster.
have your shop check your alignment values, all they have to do is install all 4 heads and scan it, this will show all the alignment angles.
Fuel man~~~
Fuel man is offline
post #5 of 9 (permalink) Old 11-04-2002, 04:29 PM
Drive XR7's Avatar
Send a message via AIM to Drive XR7
I ran 245/50/16s on my front, and found the insides wore much quicker than the outsides. I got a 4 wheel alignment, but the edges still wore... I'd attribute that to putting on a tire that was much bigger than the stock 225/60/16s.
Jason
2003 SVT Mustang Cobra #5364
2001 Pontiac Grand Prix GTP
1991 Mercury Cougar XR7 5.0L - SOLD!
Drive XR7 is offline
post #6 of 9 (permalink) Old 11-04-2002, 10:57 PM Thread Starter
Done, done, and done - it's deathered - and I run the stock 215/70R15 size - and still have the problem - even within one, onh-undredth of the specs.
Any other factors?
drl176 is offline
post #7 of 9 (permalink) Old 11-05-2002, 05:06 PM
check
Check the strut rod bushings and "A" arm bushings.
Let us know
Fuel man~~~
Fuel man is offline
post #8 of 9 (permalink) Old 11-11-2002, 12:25 AM
Find a competent front end shop. Most are not
lahowell is offline
post #9 of 9 (permalink) Old 11-11-2002, 10:53 AM
Refrigerator Raider Hater
GreenBird's Avatar
See about taking it to a suspension shop that deals with big trucks. They know their stuff.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
