T-bird and Stang GT center caps.. - TCCoA Forums
post #1 of 5 (permalink) Old 11-06-2002, 04:17 PM Thread Starter
can they be swapped out? i seen some nice GT stang wheels i wanted to buy, but i need to know can the center caps be swapped out.
silvershot is offline
post #2 of 5 (permalink) Old 11-06-2002, 06:41 PM
Depends on the wheel. All the Mustang caps come out, but which Mustang rim are you talking about and which T0bird rim are you talking about???
Mustang5L5 is offline
post #3 of 5 (permalink) Old 11-09-2002, 07:27 AM
Send a message via AIM to RedBird
Thumbs down mustang wheels
I'm pretty sure Mustang wheels won't fit the T-Bird. I had the same thought and looked into it. I'm pretty sure the bolt circle is different, 4-1/4 for T-Bird and 4-1/2 for the Mustang. Look at www.tirerack.com I think they have a Thunderbird SVT wheel that looks the same as the Mustang SVT wheel.
RedBird is offline
post #4 of 5 (permalink) Old 11-09-2002, 07:59 AM
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Stang wheels have different bolt patterns than the birds. Which means Mustang rims will not fit onto a bird without a bolt pattern swap.
The stangs have a 4.5 bolt pattern while the MN12 has a 4.25 ....you are correct RedBird.
Now as or the center caps fitting, it depends on the wheels.... there are ALOT of stang wheels out there....LOL
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #5 of 5 (permalink) Old 11-09-2002, 04:02 PM
Yeah, MN12's and Foxes have different offsets/bolt patterns. I own one of each and tried to swap my Cobra rims to my Mark VIII when i found out the hard way.
But as for center caps. I can visualize a few rims that they might swap....but there are a LOT of stang rims and tbird rims to pick from.
Right off the top of my head, i believe the sunflower 15" T-bird rim and the 17" '93 Cobra share the same center cap. There may be others
