Blowing fuse! - TCCoA Forums
post #1 of 3 (permalink) Old 11-09-2002, 06:26 AM Thread Starter
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Blowing fuse!
Okay, so I just changed the fuse for the 7th time! It just keeps on blowing!!! It is the one for the interior/trunk/hood lamps and power mirrors (15A). Why is it doing that? It's quite annoying not being able to see when you get into the car at night or trying to see in the trunk. Anyone else ever have this problem?
I am now out of fuses. It usually takes a few days and it will just blow again after I put a new one in. This last time I put a 20A in there because I ran out of 15's and it still blew. I don't think that was the smartest thing to do though....
There is one light bulb blown out (Over head w/ sunroof), could that cause this to happen? I doubt it but I just can't think of anything else. There is probably a short in the circuit somewhere... but I hope not!
Thanks for any help!
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #2 of 3 (permalink) Old 11-09-2002, 12:30 PM
Refrigerator Raider Hater
GreenBird's Avatar
I think you'll find a short. Since they are in parallel, a blown bulb would decrease the resistence of the circuit, but since there are motors and alot of other bulbs, it would not create a large disturbance.
Id start with the area around your blown bulb.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 3 (permalink) Old 11-10-2002, 01:18 AM
ZackG's Avatar
i had the same problem with mine, turned out it was teh power mirror switch. hope this helps.
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
