check engine light Excessive EGR flow - TCCoA Forums
post #1 of 13 (permalink) Old 07-29-2002, 10:58 PM Thread Starter
where do I start with this one. My car has had a little bit of a rough idle. I have a 94 4.6 is there any easy way of changin this valve or what should I check first
chris is offline
post #2 of 13 (permalink) Old 07-29-2002, 11:53 PM
5w30 Guzzler
chilipepprflea's Avatar
Send a message via AIM to chilipepprflea
what code was thrown or what was the exact description of the code?
chilipepprflea is offline
post #3 of 13 (permalink) Old 07-30-2002, 07:57 AM
99.999% gaurentee it's your Differential Pressure Feedback EGR (DPFE) sensor. This sensor detects the difference in pressure between two sample tubes that connect to the main EGR feed tube. The sensor can not be cleaned, only replaced. Clear the code if you can and see if it comes back. If it does come back, the sensor will need to be replaced ... cost about $60-$80 and is very easy to do.
MyCarMods is offline
post #4 of 13 (permalink) Old 07-30-2002, 11:55 AM Thread Starter
how do I know that its this sensor and not the egr valve itself. Is there anyway of checking it. The egr valve itself is a pain in the *** it looks like to remove. I have a 94 where is this sensor and would having a bad sensor possible cause my slight rough idle. I have had the rough idle for a while now and when the check engine light finally came on I figured it could be the problem. I did drive the car for about 4 hours on the highway with no problems. I think that the car is running a little rich Im not getting the best gas mileage and the mufflers drip some water. I don't know if that is normal.
chris is offline
post #5 of 13 (permalink) Old 07-30-2002, 12:06 PM Thread Starter
the code that was thrown was P0402 I believe that the code description is excessive egr flow. Thanks for any help
chris is offline
post #6 of 13 (permalink) Old 07-30-2002, 01:09 PM
The EGR valve should be vacuum actuated ... simple to test
post #7 of 13 (permalink) Old 07-30-2002, 01:20 PM Thread Starter
so just get a hand pump and test the valve. how do you go about testing it though
chris is offline
post #8 of 13 (permalink) Old 07-30-2002, 01:39 PM
attach a small draw tube to the vacuum nipple and "suck" ... something should happen (internal diaphram opens/closes). If nothing happens, the valve is broken. Again, I highly doubt the valve is the cause ... could be, but doubt it. I have had this happen on all three Ford that I have owned! Each time it has been the DPFE sensor.
post #9 of 13 (permalink) Old 07-30-2002, 03:22 PM Thread Starter
would this sensor cause the car to act up. I have a little bit of a rough idle could that be the cause of it
chris is offline
post #10 of 13 (permalink) Old 07-30-2002, 04:04 PM
EGR isn't supposed to be open during idle, only during partial load situations, so yes, it would cause a funky idle is stuck in the open position.
post #11 of 13 (permalink) Old 07-31-2002, 02:25 AM
Thumbs up Like MyCarMods says
Just to further back up what he says the action of the valve when suction is applied is better observed when it has been removed. You can watch the valve move up and down which means you can see if it sticks or not. (the valve stem can get coked up)
Hope this helps
Chris...............
Chris W is offline
post #12 of 13 (permalink) Old 07-31-2002, 11:57 AM Thread Starter
its a pain in the *** to remove the egr valve on the 94 though. Some guy told me you have to take off the whole intake. Or is there an easier way of doing it
chris is offline
post #13 of 13 (permalink) Old 07-31-2002, 10:12 PM Thread Starter
i tried the vacuum line suck trick that you said and it sounded like the valve was opening when i sucked. I also reset the computer and the code hasn't come back its been about 2 days and the light hasn't come back on. what should I do. Would a bad sensor cause the rough idle or would it just be a bad egr.
chris is offline
