motor mounts - TCCoA Forums
post #1 of 7 (permalink) Old 10-29-2007, 04:24 PM Thread Starter
94fastbird's Avatar
Send a message via MSN to 94fastbird
motor mounts
is any one running solid rubber motor mounts? do they respond alot better than the fluid filled. another ? would it be ok to run just solid motor mounts, it would probably vibrate like crazy? cause i made a set up when i did my motor just never put them in. what ur inputs on this solid rubber, or solid mounts, what the way to go?
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #2 of 7 (permalink) Old 10-29-2007, 04:50 PM
well I have a 93 TBird 5.0. I swapped out the fluid filled with the solids. And honestly I haven't noticed any vibration issues. I recently swapped solids into my 87 5.0 and had no issues with vibration either.
Thunderbird Family -
93 Thunderbird LX V8 Mods:Blaupunkt Bahamas MP46, Blaupunkt GT Speakers, Blaupunkt 12" Sub, K&N Intake, Taurus Cupholder, MSD Cap, Rotor, Coil, and Wires, Bosch Super Copper Spark Plugs, Bosch Battery, 93 SC Rims W/Fuzion Tires
87 Thunderbird Sport V8 Mods:Blaupunkt Bahamas MP46, Blaupunkt GT Speakers, MSD Cap and Rotor, Autolite Platinum Spark Plugs, Bosch Battery
Axlehead is offline
post #3 of 7 (permalink) Old 10-30-2007, 02:11 AM
decipha's Avatar
hmm, i have solids on my 351w in my bird, can't tell you about the vibration as the car isin't back together yet
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #4 of 7 (permalink) Old 10-30-2007, 08:37 AM
The Great Obucina's Avatar
I have solid rubber mounts and feel no vibration. They are now a little over two years old.
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 7 (permalink) Old 10-30-2007, 09:54 PM
BIG PETE's Avatar
The vibration issue is only noticable at idle. I have solids on mine, and thre is a very slight rumble. However, it doesn't feel much more severe than the fluid ones did, since the exhaust system masks a lot of it. An,d it's negligible at any other throttle setting, outside of idle.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #6 of 7 (permalink) Old 11-12-2007, 04:50 PM
IM waiting for the Poly ones to surface from ChuckW it will be nearly the same price and soon to be JL approved I hope. Search threads for it. I wondered about vibration issues myself, good that no one is getting sea sick with using solids. These mounts look freaking awesome and will handle anything I have planned for the car.
post #7 of 7 (permalink) Old 11-12-2007, 08:04 PM
Solid rubber mounts here...no complaints.
-Rod
