Header is leaking - TCCoA Forums
post #1 of 7 (permalink) Old 10-30-2007, 07:22 PM Thread Starter
95xbird's Avatar
Header is leaking
My passenger side header is leaking from the head.Is there any real good way to get to the manifold/header bolts???Can I pull the fender liner and access the studs from there???
Larry
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #2 of 7 (permalink) Old 10-30-2007, 08:31 PM
96dirtybird's Avatar
Free bump, I have the same issue with the driver side, will that method also work for me?
96dirtybird is offline
post #3 of 7 (permalink) Old 10-30-2007, 09:52 PM
BIG PETE's Avatar
Passenger side would be a mess to get to with all the A/C equipment in the way. But, as for the driver's side, I was able to swap the manifold in the car fairly easily. It took two univeral joints and several extensions. I was able to snake the wratchet through the numerous holes in the K-member and frame, getting easy access to the nuts. I think they are 13mm if I recall.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #4 of 7 (permalink) Old 10-31-2007, 03:40 PM
twin turbo 281's Avatar
yep you just have to tough it out or pull the motor haha
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #5 of 7 (permalink) Old 10-31-2007, 04:28 PM
Faster than Porkchop
cjchevez's Avatar
Try unbolting the motor mounts and moving the engine to the side .
You should have enough clearance to work .
Thats how I did my head swap but I installed the heads with the manifolds already on the heads .
Hope this helps .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #6 of 7 (permalink) Old 10-31-2007, 09:45 PM Thread Starter
95xbird's Avatar
Pete
All of my A/C junk is gone and out of the way.I figure there is no need for it.Maybe I will hook it all back up later on.I still have the parts put away for it.
I am glad you find this humerous.Altough lifting the motor is not hard at all.I can have one of these engine's out withen a few hours.I was just curious if there was an easier way to do this.
Hope this helps .
Carlo's,
I might go that route when I do this.Sounds like it would out alittle better than lifting the motor out.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #7 of 7 (permalink) Old 11-01-2007, 10:02 AM Thread Starter
95xbird's Avatar
bump
Anyone else have any more idea's?
Its slow, Really.
LS1 KILLER
95xbird is offline
