02 explorer, pushrod stuck ? - TCCoA Forums
post #1 of 7 (permalink) Old 10-30-2007, 10:24 PM Thread Starter
I have a 2002 explorer engine,4.6l, from a test vehicle. it should only have about 9,000 miles on it. The engine is very clean so the mileage should be correct. I had someone put in some crower cams then after the swap he showed me that a push rod on cylindar 6 gets stuck. I dont know if its intake or exhaust at the moment. It will go down but not come back up unless its forced back up. The problem could be that the engine just set for a while with that pushrod left open and its gummed up or rusted in there. This guy who did my cam swap now wants $150 to take it apart and put back togather. I suggested just trying to throw some lubrication in there and if it gets loose then im good to go. He strongly advised against it. What are the chances that all i need to do is just throw some oil in there. I dont want to spend more on this engine. Im debating taking it apart myself because he has the new cams in so hopfully i can reverse engineer it. Im going to start tearing off my cams off the old tbird engine that this explorer is replacing.
Should i just lube it or is that risky that even if it moves free it might lock up one day while im doing 5,000 rpm's?
tbirdkilla is offline
post #2 of 7 (permalink) Old 10-30-2007, 10:32 PM
pushrod? on a mod motor? lol
where exactly is it that your talking about?
post #3 of 7 (permalink) Old 10-30-2007, 10:37 PM
Fry Rice Specialist
Casper's Avatar
it's either the valve or the cam follower that you are talking about.
either slightly bent valve or incorrectly installed cam follower?
CarDomain Page
Casper is offline
post #4 of 7 (permalink) Old 10-30-2007, 10:45 PM
JCG1's Avatar
You mean the pushrod that is surrounded by that big spring? LOL
That would be a valvestem.
I wouldn't pay the guy any more money to work on a modular engine if I were you.
I say he f#cked the cam install and bent you a valve.
Renegade 4.6 SOHC, Cobra Crank, Manley Rods, Custom coated Diamond Pistons 10.75:1 cr w/valve reliefs, PnP npi heads, Comp Cams, 70mm TB, Maurader Intake Assembly w/80mmMAF, 24# inj, Walbro 190lph, FRPP shortys, custom 2.25 dual exh, SCT Excal2, Dirtyd0g TC; RoadmasterTranz Police Duty 4R70W (mild J-mod).
14.46 @ 95.59 / 14.50 @ 95.91 tuned by Darrin at BC Automotive
14.58 @ 94.13 Vid by DJChicago
JCG1 is offline
post #5 of 7 (permalink) Old 10-30-2007, 10:55 PM
Fry Rice Specialist
Casper's Avatar
90% chance of true factor.
the other 10% is just to give you hope.
CarDomain Page
Casper is offline
post #6 of 7 (permalink) Old 11-05-2007, 10:10 PM Thread Starter
Yes, its the valve stem.
I think im going to take my broken tbird motor apart for practice and then do this explorer one. unfortunately i didnt rotate the engine before i gave it to him to do the install. Where can i find the valve spring compressor that works on these engines?
post #7 of 7 (permalink) Old 11-05-2007, 10:11 PM
The Great Obucina's Avatar
Jason at the parts counter.
"Booyah". Stu Scott.
The Great Obucina is offline
