Starter problem after headswap - TCCoA Forums
post #1 of 14 (permalink) Old 10-30-2007, 11:41 PM Thread Starter
Amateur Expert
Embalmer's Avatar
Send a message via AIM to Embalmer
In a nutshell, here's the problem. The starter won't fully engage the flexplate after the headswap. We pulled the motor to do the swap and changed the converter to an 11 1/4 Marauder spec with the corresponding 6 bolt flexplate. Now it's all back together and when turning the key, the armature ejects and spins but does not engage the flexplate teeth. We even replaced the starter with a new one thinking it wasn't strong enough to work, but the new one does the same thing. Any ideas???
2007 Ford Mustang GT Premium - SOLD March 2014.
2013 Ford Taurus SHO (TUXESHO) Tuxedo Black Bone stock for now.
Embalmer is offline
post #2 of 14 (permalink) Old 10-31-2007, 02:45 PM
Fry Rice Specialist
Casper's Avatar
can you physically turn the engine over using the front crank nut with no binding?
CarDomain Page
Casper is offline
post #3 of 14 (permalink) Old 10-31-2007, 03:21 PM Thread Starter
Amateur Expert
Embalmer's Avatar
Yes. No issues with the motor being bound up. We can physically see the starter is just not engaging the flexplate but do not know why.
Embalmer is offline
post #4 of 14 (permalink) Old 10-31-2007, 04:26 PM
Faster than Porkchop
cjchevez's Avatar
Maybe You installed The Flexplate Back wards ?
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #5 of 14 (permalink) Old 10-31-2007, 04:38 PM
94fastbird's Avatar
Send a message via MSN to 94fastbird
thats a very real possibility could of put it on backwards
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #6 of 14 (permalink) Old 10-31-2007, 05:08 PM
Refrigerator Raider Hater
GreenBird's Avatar
Not physically possible.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #7 of 14 (permalink) Old 10-31-2007, 05:27 PM Thread Starter
Amateur Expert
Embalmer's Avatar
I was just gonna reply to that. Not only would it interfere with the motor, you couldn't bolt up the converter and the bolt holes wouldn't line up with the crank.
Embalmer is offline
post #8 of 14 (permalink) Old 10-31-2007, 09:14 PM
Bakstoy's Avatar
Wrong Flex plate maybe???
08' Jeep Commander 3.7L AWD
86' Blue Bird 4.6L DOHC 5spd
86' Black Bird 2.3L auto
Bakstoy is offline
post #9 of 14 (permalink) Old 10-31-2007, 10:07 PM Thread Starter
Amateur Expert
Embalmer's Avatar
I cross referenced the part number on the flexplate and basically it is correct for any 6 bolt crank & 11.25" converter combination from 1999-2004. I suppose it is possible that the plate was stamped wrong.
Embalmer is offline
post #10 of 14 (permalink) Old 11-01-2007, 05:30 PM
GreenBird's Avatar
Did the tranny bolt to the engine as easy as the last time you swapped? Maybe the TC is not fully seated?
96 Alpine Green V8
post #11 of 14 (permalink) Old 11-01-2007, 06:59 PM Thread Starter
Amateur Expert
Embalmer's Avatar
Yes. The TC was installed properly. I've done a few of them now and I know how to slide it on the input shaft and turn, then slide and turn. The relationship between the TC and the bellhousing is the same as it was before. Also, there is a couple of threads showing on the converter studs with the nuts torqued down just like before.
Embalmer is offline
post #12 of 14 (permalink) Old 11-02-2007, 12:49 AM
ClintD's Avatar
Just to eliminate the possibility, I wold mark one tooth and then spin the engine by hand and count the teeth. Then compare it to the original.
ClintD is offline
post #13 of 14 (permalink) Old 11-05-2007, 09:08 AM Thread Starter
Amateur Expert
Embalmer's Avatar
Problem solved. When we bolted the bellhousing and the motor together, the last bolt on the top did not line up correctly. It was almost a half a bolt off! So, we decided the starter teeth and flexplate were not lining up correctly because the trans was rotated just slightly, and we were right. The starter armature was actually just barely interfering with the flexplate. So, we disconnected the motor and trans and started over making sure all the bolts lined up. Got the starter back in and she fired up on the third crank!
Embalmer is offline
post #14 of 14 (permalink) Old 11-05-2007, 09:10 AM
Bakstoy's Avatar
Glad to hear you got it fixed Jim
Bakstoy is offline
