valve tick? - TCCoA Forums
post #1 of 6 (permalink) Old 11-01-2007, 11:40 PM Thread Starter
Bone Stock
mngsserder911's Avatar
Send a message via AIM to mngsserder911
valve tick?
Hey guys, just wondering if this is what i think it is *not quite sure*
When my car is at idle at a light or in the driveway i can hear a ticking noise. but when i accelerate the noise goes away. I have a bad feeling it is getting to be the time i just do the PI swap and get rid of the heads i got and get all new valves springs, and followers.
Any input would be great.
1997 Ford Thunderbird LX
4.6L V8
15.41 @ 89.87 MPH
-Cat-back 2.5" flowmaster 40 series (Cut-Outs Coming Soon)
-PI Heads & Cams (Coming Soon)
MY P1443 CURE - CHANGED SPARK PLUGS
http://www.cardomain.com/ride/2055391
mngsserder911 is offline
post #2 of 6 (permalink) Old 11-02-2007, 12:43 AM
94fastbird's Avatar
Send a message via MSN to 94fastbird
is it a loud tick, or a barely noticable
Current Mods:
balanced & blueprinted block. by my dad & I @ (The Engine Shop INC.) i'm running manley forged i beam rods, forged manely .020 16cc dish pistons, forged 8 bolt crankshaft thats been polished, corba high volume oil pump, block has been align bored & decked. ported and polished early production heads, heads have been milled, 3 angle valve grind, ported exhaust manifolds, gasket matched intake, dual inlet dual outlet dynomax turbo muffler underseat with 3inch turndowns. transmission heavy duty clutches, b&m shift kit, frrp t lock with 373.
Future Mods:
pi swap with some comp cams and the new trickflow intake, high stall torque converter and mark 8 drive shaft, kooks 3/4 lenth headers and xcal2
94fastbird is offline
post #3 of 6 (permalink) Old 11-02-2007, 01:48 PM Thread Starter
Bone Stock
a very low volume tick... kinda sounds like a diesel, but goes away after i start moving
4.6L V8
15.41 @ 89.87 MPH
post #4 of 6 (permalink) Old 11-02-2007, 01:57 PM
94fastbird's Avatar
i know mine did that it was getting wore out, it's not necessarily a bad thing, could have a exhaust leak very small one, then i rebuilt my motor it went away, now mine has a little knock when i first start it up cause of the forged pistons. they just gotta warm up.
Current Mods:
Future Mods:
post #5 of 6 (permalink) Old 11-03-2007, 12:43 AM
Gcline's Avatar
It could be an injector tick too. Just run some seafoam through your gas, and if you want to through the intake to clean all the carbon up.
Daily Driver, 38mpg!
Gcline is offline
post #6 of 6 (permalink) Old 11-03-2007, 09:21 PM
more than likely it is a hydralic lifter/lash adjuster, either you have a bad one which doesn't pressure up under 1500rpm (common worn) or you have a damaged one in which case the tip has broken kicking the follower out and now the adjuster is slapping against the cam (less likely) either way if you do a PI swap with used heads have the adjusters checked, or if you go with new, make sure you pre-soak them... just my $0.02.... I've seen a lot of this.
