replaced timing chains due to wear? - TCCoA Forums
post #1 of 10 (permalink) Old 11-03-2007, 01:14 AM Thread Starter
SuperNewbie
supergordo's Avatar
Has anyone had to replace the timing chains and/or tensioners in your 4.6? I'm curious to see what symptons anyone has experienced.
Thanks!
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #2 of 10 (permalink) Old 11-03-2007, 05:02 AM
twin turbo 281's Avatar
Im now running 140k on factory chains and gears with stage 2 cams(for 3 years now). Everything is still doing good.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #3 of 10 (permalink) Old 11-03-2007, 09:23 PM
on one of the mustangs I did a PI swap on we had to replace the chains and guides, chains had a lot of play in them when they were off of the engine, and before we did the swap it was making a griding sound behind the timing cover, the guides were down to bare metal, so how one of the guide bolts was missing, probably what caused the excessive wear
post #4 of 10 (permalink) Old 11-03-2007, 09:28 PM
Fry Rice Specialist
Casper's Avatar
mind stock npi at tear down at 196k miles only shows minimal wear on the chain guide.
CarDomain Page
Casper is offline
post #5 of 10 (permalink) Old 11-03-2007, 10:40 PM
Wicked_Paintball's Avatar
My mechaninc says these timing chains are not supposed to ever need replacing unless some other part causes the failure. . . for example. . .if your guide rails fail.
Wicked_Paintball is offline
post #6 of 10 (permalink) Old 11-04-2007, 06:30 PM
nickmckinney's Avatar
Only need to replace the chains if the guides are worn to metal IMHO. I always replace the curved guide and always use the cast iron tensioners.
nickmckinney is offline
post #7 of 10 (permalink) Old 11-13-2007, 11:27 AM
Banned
91bluecoupe's Avatar
I had to replace the passenger side tensioner after doing the PI cam swap it did not pump up, had to take the hole thing apart again to....crap.....
91bluecoupe is offline
post #8 of 10 (permalink) Old 11-13-2007, 11:39 AM
My chains are doing well at 262k miles.
mercenvy is offline
post #9 of 10 (permalink) Old 11-13-2007, 01:05 PM
Traveler's Avatar
Never heard of a set going bad... Unless as has been mentioned something else fails and causes it. I had to replace a set of heads on mine (long story) but still use the original tensioners, guides, and chains. they showed little if any wear.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 10 (permalink) Old 11-13-2007, 02:10 PM
278K on my crown vic, and the timing cover has never been off the motor.
