It's in BUT..... - TCCoA Forums
post #1 of 5 (permalink) Old 11-04-2007, 04:52 PM Thread Starter
ROLLINTHUNDER's Avatar
It's in BUT.....
Im having a similar problem as aonother guy had on here. I swapped in my 97 mark motor in my 95 bird using my harness and have no spark or injector pulse. Im getting power to both coil packs as well as the injectors but nothing. EDIS looks good, I have the ground strap from the block to the frame rail, checked the main connector, checked the cam and the crank sensor but it does nothing but crank. This is definatly a pain in the ***.
ROLLINTHUNDER is offline
post #2 of 5 (permalink) Old 11-04-2007, 06:19 PM
check and make sure that u are getting a good crank and cam signal to the eec,i believe the crank triggers spark and the cam triggers the injector pulse width,are you getting the 2 sec fuel pump burst when u turn the key on ?
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #3 of 5 (permalink) Old 11-04-2007, 10:11 PM
I'd start with checking the EEC grounds (pull the EEC connector and verify that each pin that should be run to ground is indeed grounded).
-Rod
post #4 of 5 (permalink) Old 11-09-2007, 06:06 PM Thread Starter
You were right racecouger. It was an orange and black wire running to the EDIS module that had to be grounded separatley. Fired right up. Thanks.
post #5 of 5 (permalink) Old 11-09-2007, 07:11 PM
No problem.
-Rod
