PO141 with new O2 sensors installed - TCCoA Forums
post #1 of 4 (permalink) Old 11-07-2007, 07:11 PM Thread Starter
Amateur Expert
Embalmer's Avatar
Send a message via AIM to Embalmer
During a headswap, we pulled the motor and replaced both upstream O2's with new Ford specific sensors. Now I'm getting this code and have cleared it twice, but it keeps coming back. Any ideas?
2007 Ford Mustang GT Premium - SOLD March 2014.
2013 Ford Taurus SHO (TUXESHO) Tuxedo Black Bone stock for now.
Embalmer is offline
post #2 of 4 (permalink) Old 11-07-2007, 07:18 PM
VicRattlehead's Avatar
thats a downstream o2 code. i offer no other help sorry.
CMP Drag Racing
VicRattlehead is offline
post #3 of 4 (permalink) Old 11-07-2007, 08:41 PM
Moderator & Teksid Whore
guitar maestro's Avatar
swap the rear O2s with each other
reset computer
if code still comes back as bank 1 sensor 2, then you got a problem with the catalytic converter on bank 1 (passenger side bank which contains cylinder #1)
if it goes to bank 2 sensor 2, then it is a faulty sensor
and if it is just a faulty sensor, just have the rear O2 functions switched off with a tune
guitar maestro is offline
post #4 of 4 (permalink) Old 11-08-2007, 06:05 AM
J.Miller's Avatar
You can clean your O2's Here is a tech article on how to clean the sensors.
Generally the cause of the fouled O2's is not a bad sensor. It is usually a vacuum leak or an old worn out fuel pressure regulator.
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
post #5 of 4 (permalink) Old 11-08-2007, 03:55 PM
Lonnie's Avatar
I've added CEL codes to my website to help your guys out by the way. I'll be adding to the lists as I have time. http://www.blueovalchips.com/index.php?action=dtc_codes
Cleaning them will help in some cases. But if the heater is burned up you need to replace it.
1992 5.0 Thunderbird Sport, 328 rwhp 347 rwtq
1995 Mark VIII, 287 rwhp 305 rwtq
I have seen the truth and it makes no sense
Lonnie is offline
